Ana içeriğe geç
LG Incite Motherboard Replacement
Neye ihtiyacın var
  1. LG Incite Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Hold the phone camera-side up and locate the rear cover.
  2. LG Incite Motherboard Replacement: adım 2, 1 resimden 1.
    • Place a thumb below the camera, apply a little pressure, and slide the cover toward the bottom of the phone.
  3. LG Incite Motherboard Replacement: adım 3, 1 resimden 1.
    • Place the plastic opening tool in the small slot below and to the left of the battery.
    • Pry the battery upward to remove it.
  4. LG Incite Motherboard Replacement, Back Panel: adım 4, 1 resimden 1.
    • Using the #00 Philips screw driver, unscrew the four 4.5mm screws located around the battery compartment.
  5. LG Incite Motherboard Replacement: adım 5, 1 resimden 1.
    • Wedge the plastic opening tool between the screen and the body of the device, using care to avoid damaging internal components.
    • Gently move the tool around the perimeter of the screen to separate it from the body.
    • You should not completely separate the screen from the device in this step.
  6. LG Incite Motherboard Replacement: adım 6, 1 resimden 1.
    • Flip the device over so the battery compartment faces up.
    • Press the scroll wheel, located in the upper-left corner, into the device to avoid damage.
    • Gently insert the plastic opening tool into the seam between the frame and front cover to separate the back panel from the device.
    • The volume, lock, and camera buttons are loose, so be careful not to misplace them.
  7. LG Incite Motherboard Replacement, Motherboard: adım 7, 3 resimden 1. LG Incite Motherboard Replacement, Motherboard: adım 7, 3 resimden 2. LG Incite Motherboard Replacement, Motherboard: adım 7, 3 resimden 3.
    • Use the metal tweezers to gently peel the yellow tab from the left edge of the phone at the two plastic bases.
    • Do not completely remove the tab from the body, it should still be connected to the phone by the orange plastic.
    • Repeat this for the white tab on the opposite side of the phone.
    • This tab also has two plastic bases adhering it to the edge of the phone.
  8. LG Incite Motherboard Replacement: adım 8, 1 resimden 1.
    • Insert your plastic opening tool underneath the speaker/camera panel, and gently pry it upwards.
    • Do not fully remove the panel! It should still be attached to the motherboard by a red and black wire.
  9. LG Incite Motherboard Replacement: adım 9, 2 resimden 1. LG Incite Motherboard Replacement: adım 9, 2 resimden 2.
    • Use the metal tweezers to gently lift the edge of the maroon tab, it should pop up easily.
    • Do not remove the tab completely, it should still be connected to the phone.
  10. LG Incite Motherboard Replacement: adım 10, 1 resimden 1.
    • Insert the plastic opening tool underneath the motherboard towards the bottom edge of the phone and gently pry it from its case.
    • Lift the motherboard and slide it towards you by hand to free it from the phone.
    • The call and end buttons may fall out when the motherboard is removed! Don't lose the buttons.
Sonuç
Kimberly Kha
163 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-18, Maness Spring 2013 Cal Poly, Team 2-18, Maness Spring 2013 üyesi
CPSU-MANESS-S13S2G18
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 757
