Ana içeriğe geç
LG Incite Touch Screen Replacement
Neye ihtiyacın var
    1. LG Incite Touch Screen Replacement, Battery: adım 1, 1 resimden 1.
      • Hold the phone camera-side up and locate the rear cover.
      FixBot'a Sor
      Yorum Ekle
    2. LG Incite Touch Screen Replacement: adım 2, 1 resimden 1.
      • Place a thumb below the camera, apply a little pressure, and slide the cover toward the bottom of the phone.
      FixBot'a Sor
      Yorum Ekle
    3. LG Incite Touch Screen Replacement: adım 3, 1 resimden 1.
      • Place the plastic opening tool in the small slot below and to the left of the battery.
      • Pry the battery upward to remove it.
      FixBot'a Sor
      Yorum Ekle
    1. LG Incite Touch Screen Replacement, Back Panel: adım 4, 1 resimden 1.
      • Using the #00 Philips screw driver, unscrew the four 4.5mm screws located around the battery compartment.
      FixBot'a Sor
      Yorum Ekle
    2. LG Incite Touch Screen Replacement: adım 5, 1 resimden 1.
      • Wedge the plastic opening tool between the screen and the body of the device, using care to avoid damaging internal components.
      • Gently move the tool around the perimeter of the screen to separate it from the body.
      • You should not completely separate the screen from the device in this step.
      FixBot'a Sor
      Yorum Ekle
    3. LG Incite Touch Screen Replacement: adım 6, 1 resimden 1.
      • Flip the device over so the battery compartment faces up.
      • Press the scroll wheel, located in the upper-left corner, into the device to avoid damage.
      • Gently insert the plastic opening tool into the seam between the frame and front cover to separate the back panel from the device.
      • The volume, lock, and camera buttons are loose, so be careful not to misplace them.
      FixBot'a Sor
      Yorum Ekle
    1. LG Incite Touch Screen Replacement, Motherboard: adım 7, 3 resimden 1. LG Incite Touch Screen Replacement, Motherboard: adım 7, 3 resimden 2. LG Incite Touch Screen Replacement, Motherboard: adım 7, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Use the metal tweezers to gently peel the yellow tab from the left edge of the phone at the two plastic bases.
      • Do not completely remove the tab from the body, it should still be connected to the phone by the orange plastic.
      • Repeat this for the white tab on the opposite side of the phone.
      • This tab also has two plastic bases adhering it to the edge of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. LG Incite Touch Screen Replacement: adım 8, 1 resimden 1.
      • Insert your plastic opening tool underneath the speaker/camera panel, and gently pry it upwards.
      • Do not fully remove the panel! It should still be attached to the motherboard by a red and black wire.
      FixBot'a Sor
      Yorum Ekle
    3. LG Incite Touch Screen Replacement: adım 9, 2 resimden 1. LG Incite Touch Screen Replacement: adım 9, 2 resimden 2.
      • Use the metal tweezers to gently lift the edge of the maroon tab, it should pop up easily.
      • Do not remove the tab completely, it should still be connected to the phone.
      FixBot'a Sor
      Yorum Ekle
    4. LG Incite Touch Screen Replacement: adım 10, 1 resimden 1.
      • Insert the plastic opening tool underneath the motherboard towards the bottom edge of the phone and gently pry it from its case.
      • Lift the motherboard and slide it towards you by hand to free it from the phone.
      • The call and end buttons may fall out when the motherboard is removed! Don't lose the buttons.
      FixBot'a Sor
      Yorum Ekle
    1. LG Incite Touch Screen Replacement, Touch Screen: adım 11, 1 resimden 1.
      • Remove the call and end buttons using the metal tweezers.
      FixBot'a Sor
      Yorum Ekle
    2. LG Incite Touch Screen Replacement: adım 12, 1 resimden 1.
      • Wedge the plastic opening tool between the screen and sides of the phone.
      • Slide the tool along the edge to loosen the screen.
      • Repeat for the opposite side.
      • Don't completely remove the screen yet to avoid damaging the screen.
      FixBot'a Sor
      Yorum Ekle
    3. LG Incite Touch Screen Replacement: adım 13, 1 resimden 1.
      • Wedge the plastic opening tool under the screen where the buttons were to loosen it.
      FixBot'a Sor
      Yorum Ekle
    4. LG Incite Touch Screen Replacement: adım 14, 2 resimden 1. LG Incite Touch Screen Replacement: adım 14, 2 resimden 2.
      • Gently peel the touch screen off from the bottom of the phone.
      • Do not damage the yellow tab in the upper right corner of the phone.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Kimberly Kha
163 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-18, Maness Spring 2013 Cal Poly, Team 2-18, Maness Spring 2013 üyesi
CPSU-MANESS-S13S2G18
4 Üyeler
60 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 26
Her zaman: 1,596
