Giriş
If your phone's touch screen breaks or malfunctions, this guide will show you how to easily remove and replace it.
Neye ihtiyacın var
Using the #00 Philips screw driver, unscrew the four 4.5mm screws located around the battery compartment.
Use the metal tweezers to gently peel the yellow tab from the left edge of the phone at the two plastic bases.
Repeat this for the white tab on the opposite side of the phone.
5 farklı kişi bu kılavuzu tamamladı.
