Ana içeriğe geç
LG Intuition Battery Replacement
Neye ihtiyacın var
    1. LG Intuition Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Turn the device so the two bottom screws are shown.
      FixBot'a Sor
      Yorum Ekle
    2. LG Intuition Battery Replacement: adım 2, 1 resimden 1.
      • Remove the two 7mm screws holding the back panel of the phone using the P5 bit and magnetic driver.
      FixBot'a Sor
      Yorum Ekle
    3. LG Intuition Battery Replacement: adım 3, 1 resimden 1.
      • Carefully use the plastic opening tool to pry the back panel of the phone from the front screen. This will expose the battery and other parts.
      FixBot'a Sor
      Yorum Ekle
    4. LG Intuition Battery Replacement: adım 4, 1 resimden 1.
      • Use the Phillips #0 screwdriver to remove the 5mm screw holding the metal bracket that protects the battery's ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    5. LG Intuition Battery Replacement: adım 5, 1 resimden 1.
      • Carefully use the plastic opening tool to pry the ribbon cable connecting the battery to the motherboard of the phone.
      FixBot'a Sor
      Yorum Ekle
    6. LG Intuition Battery Replacement: adım 6, 2 resimden 1. LG Intuition Battery Replacement: adım 6, 2 resimden 2.
      • Gently raise the battery from its compartment.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Thomas Morrissey
616 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G4, Peak Fall 2018 UMass Dartmouth, Team S3-G4, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S3G4
3 Üyeler
42 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 34
Son 30 gün: 45
Her zaman: 592
