Ana içeriğe geç
LG Intuition Power Button Replacement
Neye ihtiyacın var
    1. LG Intuition Power Button Replacement, Battery: adım 1, 1 resimden 1.
      • Turn the device so the two bottom screws are shown.
      FixBot'a Sor
      Yorum Ekle
    2. LG Intuition Power Button Replacement: adım 2, 1 resimden 1.
      • Remove the two 7mm screws holding the back panel of the phone using the P5 bit and magnetic driver.
      FixBot'a Sor
      Yorum Ekle
    3. LG Intuition Power Button Replacement: adım 3, 1 resimden 1.
      • Carefully use the plastic opening tool to pry the back panel of the phone from the front screen. This will expose the battery and other parts.
      FixBot'a Sor
      Yorum Ekle
    4. LG Intuition Power Button Replacement: adım 4, 1 resimden 1.
      • Use the Phillips #0 screwdriver to remove the 5mm screw holding the metal bracket that protects the battery's ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    5. LG Intuition Power Button Replacement: adım 5, 1 resimden 1.
      • Carefully use the plastic opening tool to pry the ribbon cable connecting the battery to the motherboard of the phone.
      FixBot'a Sor
      Yorum Ekle
    6. LG Intuition Power Button Replacement: adım 6, 2 resimden 1. LG Intuition Power Button Replacement: adım 6, 2 resimden 2.
      • Gently raise the battery from its compartment.
      FixBot'a Sor
      Yorum Ekle
    1. LG Intuition Power Button Replacement, Plastic Motherboard Shield: adım 7, 1 resimden 1.
      • Remove the thirteen 5mm screws holding the plastic shield covering the motherboard using the Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. LG Intuition Power Button Replacement: adım 8, 1 resimden 1.
      • Carefully use the plastic opening tool to pry the plastic shield from the motherboard. This will expose the motherboard and ribbon cables for each component.
      FixBot'a Sor
      Yorum Ekle
    1. LG Intuition Power Button Replacement, Camera: adım 9, 1 resimden 1.
      • Carefully use the plastic opening tool to pry the ribbon cable below the camera itself from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. LG Intuition Power Button Replacement: adım 10, 1 resimden 1.
      • Using the ribbon beneath the camera lift it upwards and pull the camera out.
      FixBot'a Sor
      Yorum Ekle
    1. LG Intuition Power Button Replacement, Volume Buttons: adım 11, 2 resimden 1. LG Intuition Power Button Replacement, Volume Buttons: adım 11, 2 resimden 2.
      • Slowly pull the ribbon cable upward releasing the volume buttons from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. LG Intuition Power Button Replacement, Screen Protector: adım 12, 2 resimden 1. LG Intuition Power Button Replacement, Screen Protector: adım 12, 2 resimden 2.
      • Carefully use the plastic opening tool to pry the ribbon cable below the volume buttons on the left side of the phone.
      • Carefully use the plastic opening tool to pry the ribbon cable to the left of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. LG Intuition Power Button Replacement: adım 13, 2 resimden 1. LG Intuition Power Button Replacement: adım 13, 2 resimden 2.
      • Carefully use the plastic opening tool to pry the wire that connects to the bottom home and back display buttons.
      • Carefully use the plastic opening tool to pry the second wire on the right side of the battery that also connects to the bottom home and back display buttons.
      FixBot'a Sor
      Yorum Ekle
    3. LG Intuition Power Button Replacement: adım 14, 1 resimden 1.
      • Carefully use the plastic opening tool to pry the motherboard from the front screen.
      FixBot'a Sor
      Yorum Ekle
    4. LG Intuition Power Button Replacement: adım 15, 2 resimden 1. LG Intuition Power Button Replacement: adım 15, 2 resimden 2.
      • Remove the 5mm Phillips #00 screw below the volume buttons holding the plastic shield onto the screen display.
      • Remove the 5mm Phillips #00 screw on the top right of the phone.
      FixBot'a Sor
      Yorum Ekle
    5. LG Intuition Power Button Replacement: adım 16, 1 resimden 1.
      • Carefully pull the ribbon cable upward and away from the front screen display.
      FixBot'a Sor
      Yorum Ekle
    6. LG Intuition Power Button Replacement: adım 17, 1 resimden 1.
      • Carefully use the plastic opening tool to pry the screen protector from the display and motherboard.
      FixBot'a Sor
      Yorum Ekle
    7. LG Intuition Power Button Replacement: adım 18, 2 resimden 1. LG Intuition Power Button Replacement: adım 18, 2 resimden 2.
      • Slowly separate the front screen from the screen protector. This will remove the screen protector from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. LG Intuition Power Button Replacement, Power Button: adım 19, 1 resimden 1.
      • Slowly separate the power button from the screen display. This will release the power button.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Thomas Morrissey
616 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G4, Peak Fall 2018 UMass Dartmouth, Team S3-G4, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S3G4
3 Üyeler
42 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 31
Son 30 gün: 47
Her zaman: 746
