Ana içeriğe geç
LG Intuition Screen Protector Replacement
Neye ihtiyacın var
  1. LG Intuition Screen Protector Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the device so the two bottom screws are shown.
    FixBot'a Sor
    Yorum Ekle
  2. LG Intuition Screen Protector Replacement: adım 2, 1 resimden 1.
    • Remove the two 7mm screws holding the back panel of the phone using the P5 bit and magnetic driver.
    FixBot'a Sor
    Yorum Ekle
  3. LG Intuition Screen Protector Replacement: adım 3, 1 resimden 1.
    • Carefully use the plastic opening tool to pry the back panel of the phone from the front screen. This will expose the battery and other parts.
    FixBot'a Sor
    Yorum Ekle
  4. LG Intuition Screen Protector Replacement: adım 4, 1 resimden 1.
    • Use the Phillips #0 screwdriver to remove the 5mm screw holding the metal bracket that protects the battery's ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  5. LG Intuition Screen Protector Replacement: adım 5, 1 resimden 1.
    • Carefully use the plastic opening tool to pry the ribbon cable connecting the battery to the motherboard of the phone.
    FixBot'a Sor
    Yorum Ekle
  6. LG Intuition Screen Protector Replacement: adım 6, 2 resimden 1. LG Intuition Screen Protector Replacement: adım 6, 2 resimden 2.
    • Gently raise the battery from its compartment.
    FixBot'a Sor
    Yorum Ekle
  7. LG Intuition Screen Protector Replacement, Plastic Motherboard Shield: adım 7, 1 resimden 1.
    • Remove the thirteen 5mm screws holding the plastic shield covering the motherboard using the Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  8. LG Intuition Screen Protector Replacement: adım 8, 1 resimden 1.
    • Carefully use the plastic opening tool to pry the plastic shield from the motherboard. This will expose the motherboard and ribbon cables for each component.
    FixBot'a Sor
    Yorum Ekle
  9. LG Intuition Screen Protector Replacement, Camera: adım 9, 1 resimden 1.
    • Carefully use the plastic opening tool to pry the ribbon cable below the camera itself from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  10. LG Intuition Screen Protector Replacement: adım 10, 1 resimden 1.
    • Using the ribbon beneath the camera lift it upwards and pull the camera out.
    FixBot'a Sor
    Yorum Ekle
  11. LG Intuition Screen Protector Replacement, Volume Buttons: adım 11, 2 resimden 1. LG Intuition Screen Protector Replacement, Volume Buttons: adım 11, 2 resimden 2.
    • Slowly pull the ribbon cable upward releasing the volume buttons from the phone.
    FixBot'a Sor
    Yorum Ekle
  12. LG Intuition Screen Protector Replacement, Screen Protector: adım 12, 2 resimden 1. LG Intuition Screen Protector Replacement, Screen Protector: adım 12, 2 resimden 2.
    • Carefully use the plastic opening tool to pry the ribbon cable below the volume buttons on the left side of the phone.
    • Carefully use the plastic opening tool to pry the ribbon cable to the left of the camera.
    FixBot'a Sor
    Yorum Ekle
  13. LG Intuition Screen Protector Replacement: adım 13, 2 resimden 1. LG Intuition Screen Protector Replacement: adım 13, 2 resimden 2.
    • Carefully use the plastic opening tool to pry the wire that connects to the bottom home and back display buttons.
    • Carefully use the plastic opening tool to pry the second wire on the right side of the battery that also connects to the bottom home and back display buttons.
    FixBot'a Sor
    Yorum Ekle
  14. LG Intuition Screen Protector Replacement: adım 14, 1 resimden 1.
    • Carefully use the plastic opening tool to pry the motherboard from the front screen.
    FixBot'a Sor
    Yorum Ekle
  15. LG Intuition Screen Protector Replacement: adım 15, 2 resimden 1. LG Intuition Screen Protector Replacement: adım 15, 2 resimden 2.
    • Remove the 5mm Phillips #00 screw below the volume buttons holding the plastic shield onto the screen display.
    • Remove the 5mm Phillips #00 screw on the top right of the phone.
    FixBot'a Sor
    Yorum Ekle
  16. LG Intuition Screen Protector Replacement: adım 16, 1 resimden 1.
    • Carefully pull the ribbon cable upward and away from the front screen display.
    FixBot'a Sor
    Yorum Ekle
  17. LG Intuition Screen Protector Replacement: adım 17, 1 resimden 1.
    • Carefully use the plastic opening tool to pry the screen protector from the display and motherboard.
    FixBot'a Sor
    Yorum Ekle
  18. LG Intuition Screen Protector Replacement: adım 18, 2 resimden 1. LG Intuition Screen Protector Replacement: adım 18, 2 resimden 2.
    • Slowly separate the front screen from the screen protector. This will remove the screen protector from the phone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Thomas Morrissey
616 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G4, Peak Fall 2018 UMass Dartmouth, Team S3-G4, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S3G4
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 457
