Ana içeriğe geç
Videoya Genel Bakış
  1. Power off the device
    • Power off the device
    • Remove the backing
  2. Remove the battery
    • Remove the battery
  3. Apple Watch Kitleri
    Screen and battery repairs just got easier.
    Hemen Alışveriş Yapın
    Apple Watch Kitleri
  4. Unscrew every screw of the bottom of the phone and use guitar picks to remove the plastic frame of the phone
    • Unscrew every screw of the bottom of the phone and use guitar picks to remove the plastic frame of the phone
  5. With a pick lift the side of the phone, in order to remove the backside
    • With a pick lift the side of the phone, in order to remove the backside
    • Repeat this step on all sides of the phone
  6. Once the back is completely off, you now have complete access to the rear camera
    • Once the back is completely off, you now have complete access to the rear camera
    • You also now have access to the rear/ front speakers, and motherboard
  7. Insert a plastic opening tool under the edge of the rear camera's press-fit connector. Lift the connector up and away from the motherboard to pop the ribbon cable free.
    • Insert a plastic opening tool under the edge of the rear camera's press-fit connector. Lift the connector up and away from the motherboard to pop the ribbon cable free.
    • Remove the rear facing camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Witrigs
62.084 İtibar
387 adet Kılavuz yazıldı
Bir Yorum
Can you upgrade the original camera with say a G5 camera?
Larry Smith - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 4
Son 30 Gün: 9
Her zaman: 1,354
