Ana içeriğe geç
LG K20 PLUS Ear Speaker Replacement
Neye ihtiyacın var
  1. LG K20 PLUS Ear Speaker Replacement, Remove the back cover and battery: adım 1, 2 resimden 1. LG K20 PLUS Ear Speaker Replacement, Remove the back cover and battery: adım 1, 2 resimden 2.
    • Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
    • Lift battery up here
  2. Dikkatli ol: adımlar 2-3 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
    LG K20 PLUS Ear Speaker Replacement, Midframe: adım 2, 1 resimden 1.
    • Remove 11 Philips screws.
  3. LG K20 PLUS Ear Speaker Replacement: adım 3, 2 resimden 1. LG K20 PLUS Ear Speaker Replacement: adım 3, 2 resimden 2.
    • Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
    • Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
    • Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
  4. LG K20 PLUS Ear Speaker Replacement, Rear-Facing Camera: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Halberd Spudger
    $2.99
    Satın Al
    • Use a Halberd spudger or an opening pick to disconnect the front camera flex from its connector on the motherboard.
  5. Dikkatli ol: adım 5 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
    LG K20 PLUS Ear Speaker Replacement, Motherboard Removal: adım 5, 1 resimden 1.
    • Using the tip of a Halberd spudger or an opening pick, disconnect the display flex cable from its socket on the motherboard.
    • Starting from the bottom, insert an opening pick between the motherboard and frame and lever apart.
    • Be careful not to break the long section of the motherboard.
    • The top part of the motherboard is lightly adhered to the frame.
    • After the motherboard is removed, compare the original and replacement part. Some components may already be installed on the replacement display assembly.
  6. LG K20 PLUS Ear Speaker Replacement, Ear Speaker Removal: adım 6, 1 resimden 1.
    • The flex cable and speaker are held in with adhesive. Use heat to soften the adhesive.
    • Carefully insert a Jimmy between the flex cable and the frame and detach the cable from the adhesive.
    • Then use the tip of a metal spudger to continue carefully prying the ear speaker up out of its housing.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Patrick
6.586 İtibar
21 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 1,060
