Giriş
Have you checked your headphones and they are not broke? Have u cleaned out the audio port only to find out that your audio is still not working. It is time to change your audio jack.
Use this guide to replace the Headphone Jack of your LG K30.
Neye ihtiyacın var
Power off your Phone before beginning disassembly.
Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
Use a spudger to carefully disconnect the front camera connector.
Use a spudger to disconnect the display cable connector.
Use the point of a spudger to pry the headphone jack out of its recess in the display assembly.
Bir başkası bu kılavuzu tamamladı.
