Ana içeriğe geç
LG K30 Motherboard Replacement
Neye ihtiyacın var
  1. LG K30 Motherboard Replacement, Battery: adım 1, 2 resimden 1. LG K30 Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Before disassembling your LG K30, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your Phone before beginning disassembly.
    • Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
  2. LG K30 Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the thirteen 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  3. LG K30 Motherboard Replacement: adım 3, 1 resimden 1.
    • Use a metal spudger or plastic opening tool to pry open the outer cover.
  4. LG K30 Motherboard Replacement: adım 4, 1 resimden 1.
    • Use the flat end of a spudger to detach the battery connector from the logic board.
  5. LG K30 Motherboard Replacement: adım 5, 2 resimden 1. LG K30 Motherboard Replacement: adım 5, 2 resimden 2.
    • Use a spudger to pry the battery from the phone.
    • There may be an adhesive on the back of the battery and the phone. Pry the battery gently to prevent puncture or damage.
    • Do not bend or puncture the battery.
  6. LG K30 Motherboard Replacement, Motherboard: adım 6, 1 resimden 1.
    • Use a spudger to carefully disconnect the front camera connector.
    • Use a spudger to disconnect the display cable connector.
  7. LG K30 Motherboard Replacement: adım 7, 2 resimden 1. LG K30 Motherboard Replacement: adım 7, 2 resimden 2.
    • Remove the motherboard assembly from the display assembly with the a spudger or hand.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 2,000
