Ana içeriğe geç
LG K30 Rear Facing Camera Replacement
Neye ihtiyacın var
    1. LG K30 Rear Facing Camera Replacement, Battery: adım 1, 2 resimden 1. LG K30 Rear Facing Camera Replacement, Battery: adım 1, 2 resimden 2.
      • Before disassembling your LG K30, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your Phone before beginning disassembly.
      • Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
      FixBot'a Sor
      Yorum Ekle
    2. LG K30 Rear Facing Camera Replacement: adım 2, 1 resimden 1.
      • Remove the thirteen 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
      FixBot'a Sor
      Yorum Ekle
    3. LG K30 Rear Facing Camera Replacement: adım 3, 1 resimden 1.
      • Use a metal spudger or plastic opening tool to pry open the outer cover.
      FixBot'a Sor
      Yorum Ekle
    4. LG K30 Rear Facing Camera Replacement: adım 4, 1 resimden 1.
      • Use the flat end of a spudger to detach the battery connector from the logic board.
      FixBot'a Sor
      Yorum Ekle
    5. LG K30 Rear Facing Camera Replacement: adım 5, 2 resimden 1. LG K30 Rear Facing Camera Replacement: adım 5, 2 resimden 2.
      • Use a spudger to pry the battery from the phone.
      • There may be an adhesive on the back of the battery and the phone. Pry the battery gently to prevent puncture or damage.
      • Do not bend or puncture the battery.
      FixBot'a Sor
      Yorum Ekle
    1. LG K30 Rear Facing Camera Replacement, Motherboard: adım 6, 1 resimden 1.
      • Use a spudger to carefully disconnect the front camera connector.
      • Use a spudger to disconnect the display cable connector.
      FixBot'a Sor
      Yorum Ekle
    2. LG K30 Rear Facing Camera Replacement: adım 7, 2 resimden 1. LG K30 Rear Facing Camera Replacement: adım 7, 2 resimden 2.
      • Remove the motherboard assembly from the display assembly with the a spudger or hand.
      FixBot'a Sor
      Yorum Ekle
    1. LG K30 Rear Facing Camera Replacement, Rear Facing Camera: adım 8, 2 resimden 1. LG K30 Rear Facing Camera Replacement, Rear Facing Camera: adım 8, 2 resimden 2.
      • Only pry on the tab, not the connector itself.
      • Use a Spudger to flip the release tab on the rear-facing camera cable ZIF connector.
      • Remove the rear-facing camera.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 32
Her zaman: 819
