Giriş
The charging port allows for the LG K7 to be charged. It can stop working for a number of reasons but the main two are shock and wear. It can be replaced in about 30 minutes with the guide below. A soldering iron will be necessary which should be used with caution.
Neye ihtiyacın var
Remove the back cover by using the plastic opening tool.
Remove battery by using the plastic opening tool.
Bir başkası bu kılavuzu tamamladı.
