Ana içeriğe geç
LG K7 Charging Port Replacement
Neye ihtiyacın var
  1. LG K7 Charging Port Replacement, Charging Port: adım 1, 2 resimden 1. LG K7 Charging Port Replacement, Charging Port: adım 1, 2 resimden 2.
    • Remove the back cover by using the plastic opening tool.
    • Remove battery by using the plastic opening tool.
  2. LG K7 Charging Port Replacement: adım 2, 1 resimden 1.
    • Remove the nine 4mm Phillips #000 screws.
    • The cover should lift off easily once the screws are out.
    • Be gentle with the frame when removing it. The plastic is very thin and can easily break.
  3. LG K7 Charging Port Replacement: adım 3, 1 resimden 1.
    • Place the plastic opening tool between the screen and the plastic edge of the phone and pry carefully until screen pops off.
    • The frame is held to the rest of the phone with plastic tabs. Release each tab one at a time around the phone for the easiest removal.
    • Do not bend the outer frame or screen when separating them. This will severely damage the phone.
  4. LG K7 Charging Port Replacement: adım 4, 1 resimden 1.
    • Place the plastic opening tool between the blue motherboard and black plate and pry until the motherboard pops off.
  5. LG K7 Charging Port Replacement: adım 5, 2 resimden 1. LG K7 Charging Port Replacement: adım 5, 2 resimden 2.
    • Heat up the four connection points using a soldering iron.
    • Once hot, gently push the port off.
    • Soldering iron is hot! Use with caution.
    • Be careful not to touch other components with the soldering iron.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Stephen Damm
167 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S3-G2, Harley Fall 2019 IUPUI, Team S3-G2, Harley Fall 2019 üyesi
IUPUI-HARLEY-F19S3G2
3 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 606
