Ana içeriğe geç
LG K7 Rear Facing Camera Replacement
Neye ihtiyacın var
  1. LG K7 Rear Facing Camera Replacement, Battery: adım 1, 2 resimden 1. LG K7 Rear Facing Camera Replacement, Battery: adım 1, 2 resimden 2.
    • Place a fingernail in slot at in the bottom edge of the phone.
    • Pull up on the back panel while holding down the rest of the phone steady with your hand.
    • Do not to pull too hard on the back panel or you may break it.
  2. LG K7 Rear Facing Camera Replacement: adım 2, 2 resimden 1. LG K7 Rear Facing Camera Replacement: adım 2, 2 resimden 2.
    • Place a fingernail in the slot at the bottom edge of the battery.
    • Pull the battery out.
  3. LG K7 Rear Facing Camera Replacement, Rear Facing Camera: adım 3, 3 resimden 1. LG K7 Rear Facing Camera Replacement, Rear Facing Camera: adım 3, 3 resimden 2. LG K7 Rear Facing Camera Replacement, Rear Facing Camera: adım 3, 3 resimden 3.
    • Remove the 9 frame screws with a JIS #00 screwdriver.
    • The bottom three screws release the port cover at the bottom of the phone. The cover should lift off easily once the screws are out.
    • Pop the camera button frame off with a spudger. The home button should come off along with the frame.
    • Be gentle with the frame when removing it. The plastic is very thin and can easily break.
  4. LG K7 Rear Facing Camera Replacement: adım 4, 2 resimden 1. LG K7 Rear Facing Camera Replacement: adım 4, 2 resimden 2.
    • Use a plastic opening tool to separate the screen from the outer frame.
    • Do not to bend the outer frame or the screen to when separating them. This can severely damage the phone.
  5. LG K7 Rear Facing Camera Replacement: adım 5, 1 resimden 1.
    • Insert the edge of a plastic opening tool underneath the camera connector that is attached to the camera by a flat, thin, and flexible sheet.
    • Slowly lever the connector free by pressing down on the opening tool's handle. The connector should be fairly solid and pop out by levering just one edge.
    • Be careful not to break or bend the connector or any part of the device you may be levering against.
Sonuç
Bir başkası bu kılavuzu tamamladı.
James Ngo
461 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S21-G5, Banghart Winter 2018 Cal Poly, Team S21-G5, Banghart Winter 2018 üyesi
CPSU-BANGHART-W18S21G5
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 423
