Ana içeriğe geç
LG K7 T-Mobile Rear Phone Camera Replacement
Neye ihtiyacın var
    1. LG K7 T-Mobile Rear Phone  Camera Replacement, Battery: adım 1, 2 resimden 1. LG K7 T-Mobile Rear Phone  Camera Replacement, Battery: adım 1, 2 resimden 2.
      • Flip the LG K7 over so that the back of the phone is facing up.
      • Locate the small notch on the bottom left side of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. LG K7 T-Mobile Rear Phone  Camera Replacement: adım 2, 1 resimden 1.
      • Insert a plastic opening tool into the notch and lift the back cover upward while holding the bottom portion of the phone down to remove it.
      FixBot'a Sor
      Yorum Ekle
    3. LG K7 T-Mobile Rear Phone  Camera Replacement: adım 3, 1 resimden 1.
      • Remove the battery.
      FixBot'a Sor
      Yorum Ekle
    1. LG K7 T-Mobile Rear Phone  Camera Replacement, Rear Phone  Camera: adım 4, 2 resimden 1. LG K7 T-Mobile Rear Phone  Camera Replacement, Rear Phone  Camera: adım 4, 2 resimden 2.
      • Located to nine 3.4 mm screws that keep that keep the phones rear housing in tacked.
      • Using a Phillips 00 screwdriver remove all nine 3.4 mm screws.
      FixBot'a Sor
      Yorum Ekle
    2. LG K7 T-Mobile Rear Phone  Camera Replacement: adım 5, 3 resimden 1. LG K7 T-Mobile Rear Phone  Camera Replacement: adım 5, 3 resimden 2. LG K7 T-Mobile Rear Phone  Camera Replacement: adım 5, 3 resimden 3.
      • Turn the phone over so the screen is facing up
      • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
      • Slide the plastic opening tool down the seams carefully to separate the screen from the rest of the phone housing.
      FixBot'a Sor
      Yorum Ekle
    3. LG K7 T-Mobile Rear Phone  Camera Replacement: adım 6, 3 resimden 1. LG K7 T-Mobile Rear Phone  Camera Replacement: adım 6, 3 resimden 2. LG K7 T-Mobile Rear Phone  Camera Replacement: adım 6, 3 resimden 3.
      • Locate the ribbon cable that holds the camera's ribbon cable in place.
      • Carefully remove the camera's ribbon cable from the motherboard using the plastic removal tool.
      • Holding the camera ribbon you just released pull upwards and the camera should release from the case.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Salem Jean
216 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G5, Nance Fall 2017 USF Tampa, Team S2-G5, Nance Fall 2017 üyesi
USFT-NANCE-F17S2G5
3 Üyeler
28 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 821
