Ana içeriğe geç
LG K7 Volume & On/Off Buttons Replacement
Neye ihtiyacın var
  1. LG K7 Volume & On/Off Buttons Replacement, Volume & On/Off Buttons: adım 1, 2 resimden 1. LG K7 Volume & On/Off Buttons Replacement, Volume & On/Off Buttons: adım 1, 2 resimden 2.
    • Remove the back cover using a plastic opening tool.
    • Remove the battery using a plastic opening tool.
  2. LG K7 Volume & On/Off Buttons Replacement: adım 2, 1 resimden 1.
    • Remove the nine 4mm Phillips #000 screws.
    • The cover should lift off easily once the screws are out.
    • Be gentle with the frame when removing it. The plastic is very thin and can easily break.
  3. LG K7 Volume & On/Off Buttons Replacement: adım 3, 1 resimden 1.
    • Pry off the silver button housing using the plastic opening tool.
  4. LG K7 Volume & On/Off Buttons Replacement: adım 4, 1 resimden 1.
    • Separate the screen from the rest of the phone using the plastic opening tool.
    • The frame is held to the rest of the phone with plastic tabs. Release each tab one at a time around the phone for the easiest removal.
    • Do not bend the outer frame or screen when separating them. This will severely damage the phone.
  5. LG K7 Volume & On/Off Buttons Replacement: adım 5, 3 resimden 1. LG K7 Volume & On/Off Buttons Replacement: adım 5, 3 resimden 2. LG K7 Volume & On/Off Buttons Replacement: adım 5, 3 resimden 3.
    • Peel off the orange cable using a plastic opening tool.
  6. LG K7 Volume & On/Off Buttons Replacement: adım 6, 1 resimden 1.
    • Remove the volume/power button cable from the rest of the phone using the plastic opening tool to break the adhesive.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jack Lepkowski
136 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S3-G2, Harley Fall 2019 IUPUI, Team S3-G2, Harley Fall 2019 üyesi
IUPUI-HARLEY-F19S3G2
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 509
