Ana içeriğe geç
LG L1200 Camera Replacement
Neye ihtiyacın var
    1. LG L1200 Camera Replacement, Inner LCD Screen: adım 1, 1 resimden 1.
      • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
      • Flip open the phone and locate the four screw covers.
      FixBot'a Sor
      Yorum Ekle
    2. LG L1200 Camera Replacement: adım 2, 1 resimden 1.
      • Remove all four screw covers by using an IPod opening tool. They should come off relatively easy.
      FixBot'a Sor
      Yorum Ekle
    3. LG L1200 Camera Replacement: adım 3, 1 resimden 1.
      • Using a T6 Torx screwdriver, remove all four screws.
      FixBot'a Sor
      Yorum Ekle
    4. LG L1200 Camera Replacement: adım 4, 3 resimden 1. LG L1200 Camera Replacement: adım 4, 3 resimden 2. LG L1200 Camera Replacement: adım 4, 3 resimden 3.
      • Once the screws are removed, use an IPod opening tool to separate the front cover from the inner screen cover.
      • Run the Ipod opening tool down both sides,disconnecting the tabs that hold the covers together.
      FixBot'a Sor
      Yorum Ekle
    5. LG L1200 Camera Replacement: adım 5, 2 resimden 1. LG L1200 Camera Replacement: adım 5, 2 resimden 2.
      • Pull the inner screen cover towards you and up in order to separate it from the front cover.
      FixBot'a Sor
      Yorum Ekle
    6. LG L1200 Camera Replacement: adım 6, 1 resimden 1.
      • Remove the tape from the bottom of the LCD screen.
      FixBot'a Sor
      Yorum Ekle
    7. LG L1200 Camera Replacement: adım 7, 3 resimden 1. LG L1200 Camera Replacement: adım 7, 3 resimden 2. LG L1200 Camera Replacement: adım 7, 3 resimden 3.
      • Carefully lift the LCD screen and peel it from the gold ribbon. The sticky connection runs all the way around the LCD screen.
      FixBot'a Sor
      Yorum Ekle
    8. LG L1200 Camera Replacement: adım 8, 3 resimden 1. LG L1200 Camera Replacement: adım 8, 3 resimden 2. LG L1200 Camera Replacement: adım 8, 3 resimden 3.
      • Flip the screen over so that you can see the outer LCD screen and the circuit board.
      • Insert spudger in the bottom right corner.
      • Lift up and move the spudger across the bottom.
      • The third photo is rotated 180 degrees.
      FixBot'a Sor
      Yorum Ekle
    9. LG L1200 Camera Replacement: adım 9, 2 resimden 1. LG L1200 Camera Replacement: adım 9, 2 resimden 2.
      • Use the pointy side of the spudger to peel off the interior tape.
      • Flip the assembly over and peel the circuit board from the screen.
      FixBot'a Sor
      Yorum Ekle
    10. LG L1200 Camera Replacement: adım 10, 2 resimden 1. LG L1200 Camera Replacement: adım 10, 2 resimden 2.
      • Use the spudger to remove the LCD screen from its backing.
      FixBot'a Sor
      Yorum Ekle
    1. LG L1200 Camera Replacement, Camera: adım 11, 1 resimden 1.
      • Carefully slide the spudger behind the main ribbon in order to separate it from the inside cover of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. LG L1200 Camera Replacement: adım 12, 2 resimden 1. LG L1200 Camera Replacement: adım 12, 2 resimden 2.
      • Use a spudger to pop off the camera ribbon from the main ribbon. The camera component should separate entirely.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Joshua Herrmann
8 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-14, Maness Spring 2010 Cal Poly, Team 6-14, Maness Spring 2010 üyesi
CPSU-MANESS-S10S6G14
4 Üyeler
88 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 29
Her zaman: 1,593
