Ana içeriğe geç
LG L1200 External Housing Replacement
Neye ihtiyacın var
    1. LG L1200 External Housing Replacement, Inner LCD Screen: adım 1, 1 resimden 1.
      • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
      • Flip open the phone and locate the four screw covers.
      FixBot'a Sor
      Yorum Ekle
    2. LG L1200 External Housing Replacement: adım 2, 1 resimden 1.
      • Remove all four screw covers by using an IPod opening tool. They should come off relatively easy.
      FixBot'a Sor
      Yorum Ekle
    3. LG L1200 External Housing Replacement: adım 3, 1 resimden 1.
      • Using a T6 Torx screwdriver, remove all four screws.
      FixBot'a Sor
      Yorum Ekle
    4. LG L1200 External Housing Replacement: adım 4, 3 resimden 1. LG L1200 External Housing Replacement: adım 4, 3 resimden 2. LG L1200 External Housing Replacement: adım 4, 3 resimden 3.
      • Once the screws are removed, use an IPod opening tool to separate the front cover from the inner screen cover.
      • Run the Ipod opening tool down both sides,disconnecting the tabs that hold the covers together.
      FixBot'a Sor
      Yorum Ekle
    5. LG L1200 External Housing Replacement: adım 5, 2 resimden 1. LG L1200 External Housing Replacement: adım 5, 2 resimden 2.
      • Pull the inner screen cover towards you and up in order to separate it from the front cover.
      FixBot'a Sor
      Yorum Ekle
    6. LG L1200 External Housing Replacement: adım 6, 1 resimden 1.
      • Remove the tape from the bottom of the LCD screen.
      FixBot'a Sor
      Yorum Ekle
    7. LG L1200 External Housing Replacement: adım 7, 3 resimden 1. LG L1200 External Housing Replacement: adım 7, 3 resimden 2. LG L1200 External Housing Replacement: adım 7, 3 resimden 3.
      • Carefully lift the LCD screen and peel it from the gold ribbon. The sticky connection runs all the way around the LCD screen.
      FixBot'a Sor
      Yorum Ekle
    8. LG L1200 External Housing Replacement: adım 8, 3 resimden 1. LG L1200 External Housing Replacement: adım 8, 3 resimden 2. LG L1200 External Housing Replacement: adım 8, 3 resimden 3.
      • Flip the screen over so that you can see the outer LCD screen and the circuit board.
      • Insert spudger in the bottom right corner.
      • Lift up and move the spudger across the bottom.
      • The third photo is rotated 180 degrees.
      FixBot'a Sor
      Yorum Ekle
    9. LG L1200 External Housing Replacement: adım 9, 2 resimden 1. LG L1200 External Housing Replacement: adım 9, 2 resimden 2.
      • Use the pointy side of the spudger to peel off the interior tape.
      • Flip the assembly over and peel the circuit board from the screen.
      FixBot'a Sor
      Yorum Ekle
    10. LG L1200 External Housing Replacement: adım 10, 2 resimden 1. LG L1200 External Housing Replacement: adım 10, 2 resimden 2.
      • Use the spudger to remove the LCD screen from its backing.
      FixBot'a Sor
      Yorum Ekle
    1. LG L1200 External Housing Replacement, Camera: adım 11, 1 resimden 1.
      • Carefully slide the spudger behind the main ribbon in order to separate it from the inside cover of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. LG L1200 External Housing Replacement: adım 12, 2 resimden 1. LG L1200 External Housing Replacement: adım 12, 2 resimden 2.
      • Use a spudger to pop off the camera ribbon from the main ribbon. The camera component should separate entirely.
      FixBot'a Sor
      Yorum Ekle
    1. LG L1200 External Housing Replacement, Logic Board: adım 13, 1 resimden 1.
      • Poke out rubber covers using a spudger or pointy object, such as a thumb tack.
      FixBot'a Sor
      Yorum Ekle
    2. LG L1200 External Housing Replacement: adım 14, 1 resimden 1.
      • Use a T6 torx screwdriver to unscrew the 6 screws that hold the back casing on.
      FixBot'a Sor
      Yorum Ekle
    3. LG L1200 External Housing Replacement: adım 15, 1 resimden 1.
      • Use IPod opening tool to separate back housing.
      • There are two tabs located on either side of the phone.
      FixBot'a Sor
      Yorum Ekle
    4. LG L1200 External Housing Replacement: adım 16, 1 resimden 1.
      • Separate the back housing from the phone.
      • Be careful not to rip out the wire (highlighted in yellow) when separating the back housing.
      FixBot'a Sor
      Yorum Ekle
    5. LG L1200 External Housing Replacement: adım 17, 1 resimden 1.
      • Use a spudger to disconnect antenna wire.
      FixBot'a Sor
      Yorum Ekle
    6. LG L1200 External Housing Replacement: adım 18, 1 resimden 1.
      • Use the IPod opening tool to pop out the logic board.
      FixBot'a Sor
      Yorum Ekle
    7. LG L1200 External Housing Replacement: adım 19, 1 resimden 1.
      • Use the IPod opening tool to disconnect the main ribbon.
      FixBot'a Sor
      Yorum Ekle
    8. LG L1200 External Housing Replacement: adım 20, 1 resimden 1.
      • Once the ribbon is detached, remove the logic board and replace if necessary.
      FixBot'a Sor
      Yorum Ekle
    1. LG L1200 External Housing Replacement, Keypad: adım 21, 1 resimden 1.
      • The back of the keypad is shown here, next to the logic board (the logic board is turned over to expose the buttons).
      FixBot'a Sor
      Yorum Ekle
    2. LG L1200 External Housing Replacement: adım 22, 2 resimden 1. LG L1200 External Housing Replacement: adım 22, 2 resimden 2.
      • Using a spudger, lift the keypad off of the tabs.
      FixBot'a Sor
      Yorum Ekle
    1. LG L1200 External Housing Replacement, External Housing: adım 23, 1 resimden 1.
      • Wedge a spudger or another harder prying tool in the connection between the top cover and the bottom cover on the right side.
      • Use a large amount of force to push the top cover off the bottom cover's blue extrusion.
      • Too much force may break the plastic of the top cover
      • When separating the top cover from the bottom cover, be careful not to tear the ribbon as you pull it out from the hinge.
      FixBot'a Sor
      Yorum Ekle
    2. LG L1200 External Housing Replacement: adım 24, 2 resimden 1. LG L1200 External Housing Replacement: adım 24, 2 resimden 2.
      • Slide the ribbon out of the slot in the joint on the left side.
      • Pull the ribbon out of the top cover with your hand.
      • Once the ribbon is removed, you can replace the covers.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Joshua Herrmann
8 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-14, Maness Spring 2010 Cal Poly, Team 6-14, Maness Spring 2010 üyesi
CPSU-MANESS-S10S6G14
4 Üyeler
88 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 40
Her zaman: 1,562
