Ana içeriğe geç
LG L1200 Keypad Replacement
Neye ihtiyacın var
    1. LG L1200 Keypad Replacement, Logic Board: adım 1, 1 resimden 1.
      • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
      • Poke out rubber covers using a spudger or pointy object, such as a thumb tack.
      FixBot'a Sor
      Yorum Ekle
    2. LG L1200 Keypad Replacement: adım 2, 1 resimden 1.
      • Use a T6 torx screwdriver to unscrew the 6 screws that hold the back casing on.
      FixBot'a Sor
      Yorum Ekle
    3. LG L1200 Keypad Replacement: adım 3, 1 resimden 1.
      • Use IPod opening tool to separate back housing.
      • There are two tabs located on either side of the phone.
      FixBot'a Sor
      Yorum Ekle
    4. LG L1200 Keypad Replacement: adım 4, 1 resimden 1.
      • Separate the back housing from the phone.
      • Be careful not to rip out the wire (highlighted in yellow) when separating the back housing.
      FixBot'a Sor
      Yorum Ekle
    5. LG L1200 Keypad Replacement: adım 5, 1 resimden 1.
      • Use a spudger to disconnect antenna wire.
      FixBot'a Sor
      Yorum Ekle
    6. LG L1200 Keypad Replacement: adım 6, 1 resimden 1.
      • Use the IPod opening tool to pop out the logic board.
      FixBot'a Sor
      Yorum Ekle
    7. LG L1200 Keypad Replacement: adım 7, 1 resimden 1.
      • Use the IPod opening tool to disconnect the main ribbon.
      FixBot'a Sor
      Yorum Ekle
    8. LG L1200 Keypad Replacement: adım 8, 1 resimden 1.
      • Once the ribbon is detached, remove the logic board and replace if necessary.
      FixBot'a Sor
      Yorum Ekle
    1. LG L1200 Keypad Replacement, Keypad: adım 9, 1 resimden 1.
      • The back of the keypad is shown here, next to the logic board (the logic board is turned over to expose the buttons).
      FixBot'a Sor
      Yorum Ekle
    2. LG L1200 Keypad Replacement: adım 10, 2 resimden 1. LG L1200 Keypad Replacement: adım 10, 2 resimden 2.
      • Using a spudger, lift the keypad off of the tabs.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Joshua Herrmann
8 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-14, Maness Spring 2010 Cal Poly, Team 6-14, Maness Spring 2010 üyesi
CPSU-MANESS-S10S6G14
4 Üyeler
88 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 30
Her zaman: 1,444
