Ana içeriğe geç
LG L1200 Logic Board Replacement
Neye ihtiyacın var
    1. LG L1200 Logic Board Replacement, Logic Board: adım 1, 1 resimden 1.
      • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
      • Poke out rubber covers using a spudger or pointy object, such as a thumb tack.
      FixBot'a Sor
      Yorum Ekle
    2. LG L1200 Logic Board Replacement: adım 2, 1 resimden 1.
      • Use a T6 torx screwdriver to unscrew the 6 screws that hold the back casing on.
      FixBot'a Sor
      Yorum Ekle
    3. LG L1200 Logic Board Replacement: adım 3, 1 resimden 1.
      • Use IPod opening tool to separate back housing.
      • There are two tabs located on either side of the phone.
      FixBot'a Sor
      Yorum Ekle
    4. LG L1200 Logic Board Replacement: adım 4, 1 resimden 1.
      • Separate the back housing from the phone.
      • Be careful not to rip out the wire (highlighted in yellow) when separating the back housing.
      FixBot'a Sor
      Yorum Ekle
    5. LG L1200 Logic Board Replacement: adım 5, 1 resimden 1.
      • Use a spudger to disconnect antenna wire.
      FixBot'a Sor
      Yorum Ekle
    6. LG L1200 Logic Board Replacement: adım 6, 1 resimden 1.
      • Use the IPod opening tool to pop out the logic board.
      FixBot'a Sor
      Yorum Ekle
    7. LG L1200 Logic Board Replacement: adım 7, 1 resimden 1.
      • Use the IPod opening tool to disconnect the main ribbon.
      FixBot'a Sor
      Yorum Ekle
    8. LG L1200 Logic Board Replacement: adım 8, 1 resimden 1.
      • Once the ribbon is detached, remove the logic board and replace if necessary.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Joshua Herrmann
8 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-14, Maness Spring 2010 Cal Poly, Team 6-14, Maness Spring 2010 üyesi
CPSU-MANESS-S10S6G14
4 Üyeler
88 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 15
Son 30 gün: 47
Her zaman: 1,584
