Ana içeriğe geç
LG L1200 Logic Board Replacement
Neye ihtiyacın var
  1. LG L1200 Logic Board Replacement, Logic Board: adım 1, 1 resimden 1.
    • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
    • Poke out rubber covers using a spudger or pointy object, such as a thumb tack.
  2. LG L1200 Logic Board Replacement: adım 2, 1 resimden 1.
    • Use a T6 torx screwdriver to unscrew the 6 screws that hold the back casing on.
  3. LG L1200 Logic Board Replacement: adım 3, 1 resimden 1.
    • Use IPod opening tool to separate back housing.
    • There are two tabs located on either side of the phone.
  4. LG L1200 Logic Board Replacement: adım 4, 1 resimden 1.
    • Separate the back housing from the phone.
    • Be careful not to rip out the wire (highlighted in yellow) when separating the back housing.
  5. LG L1200 Logic Board Replacement: adım 5, 1 resimden 1.
    • Use a spudger to disconnect antenna wire.
  6. LG L1200 Logic Board Replacement: adım 6, 1 resimden 1.
    • Use the IPod opening tool to pop out the logic board.
  7. LG L1200 Logic Board Replacement: adım 7, 1 resimden 1.
    • Use the IPod opening tool to disconnect the main ribbon.
  8. LG L1200 Logic Board Replacement: adım 8, 1 resimden 1.
    • Once the ribbon is detached, remove the logic board and replace if necessary.
Sonuç
Joshua Herrmann
8 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-14, Maness Spring 2010 Cal Poly, Team 6-14, Maness Spring 2010 üyesi
CPSU-MANESS-S10S6G14
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 1,243
