Ana içeriğe geç
LG LX150 Battery Replacement
  1. LG LX150 Battery Replacement, Back Cover: adım 1, 3 resimden 1. LG LX150 Battery Replacement, Back Cover: adım 1, 3 resimden 2. LG LX150 Battery Replacement, Back Cover: adım 1, 3 resimden 3.
    • First locate the button and the bottom of the cover where the arrow is. Press down on the button.
    • While pushing down on the button, slide the cover up towards the hinge until the cover comes off.
    • The battery will be visible after removing the back cover.
  2. LG LX150 Battery Replacement, Battery: adım 2, 2 resimden 1. LG LX150 Battery Replacement, Battery: adım 2, 2 resimden 2.
    • Simultaneously push the battery forward and pull up from the bottom.
  3. LG LX150 Battery Replacement: adım 3, 1 resimden 1.
    • Once the battery is loose it can be easily removed. The phone's ID tag will be visible once the battery is removed.
    • Be careful of damaged or leaking batteries. If your battery appears damaged, remove it with care and find a replacement.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrea
110 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-44, Garner Spring 2010 Cal Poly, Team 10-44, Garner Spring 2010 üyesi
CPSU-GARNER-S10S10G44
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 1,604
