Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
How to Remove the Battery
  1. First locate the button and the bottom of the cover where the arrow is. Press down on the button. While pushing down on the button, slide the cover up towards the hinge until the cover comes off. The battery will be visible after removing the back cover.
    • First locate the button and the bottom of the cover where the arrow is. Press down on the button.
    • While pushing down on the button, slide the cover up towards the hinge until the cover comes off.
    • The battery will be visible after removing the back cover.
  2. Simultaneously push the battery forward and pull up from the bottom. Simultaneously push the battery forward and pull up from the bottom.
    • Simultaneously push the battery forward and pull up from the bottom.
  3. Once the battery is loose it can be easily removed. The phone's ID tag will be visible once the battery is removed.
    • Once the battery is loose it can be easily removed. The phone's ID tag will be visible once the battery is removed.
    • Be careful of damaged or leaking batteries. If your battery appears damaged, remove it with care and find a replacement.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrea
110 İtibar
4 adet Kılavuz yazıldı
Takım
Cal Poly, Team 10-44, Garner Spring 2010 Cal Poly, Team 10-44, Garner Spring 2010 üyesi
CPSU-GARNER-S10S10G44
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,318
