Ana içeriğe geç
LG LX150 Screen Replacement
Neye ihtiyacın var
  1. LG LX150 Screen Replacement, Front Cover: adım 1, 3 resimden 1. LG LX150 Screen Replacement, Front Cover: adım 1, 3 resimden 2. LG LX150 Screen Replacement, Front Cover: adım 1, 3 resimden 3.
    • Use the spudger to pry out the indicated rubber squares.
    • Use the #0 Phillips screwdriver to take out the revealed screws.
  2. LG LX150 Screen Replacement: adım 2, 3 resimden 1. LG LX150 Screen Replacement: adım 2, 3 resimden 2. LG LX150 Screen Replacement: adım 2, 3 resimden 3.
    • Carefully lodge the spudger between the face plate and the hinge mechanism.
    • Gently pry the face plate until it releases from place holders.
  3. LG LX150 Screen Replacement, Screen: adım 3, 2 resimden 1. LG LX150 Screen Replacement, Screen: adım 3, 2 resimden 2.
    • Apply even amounts of force upon removing screen, otherwise cracking may occur.
    • Gently loosen the screen from its adhesive by pressing around the screen's rear perimeter with a spudger. Place upward pressure in crevices between face plate and screen.
    • Carefully use both thumbs and apply pressure to the back of the screen to pop out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tye Barba
88 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-44, Garner Spring 2010 Cal Poly, Team 10-44, Garner Spring 2010 üyesi
CPSU-GARNER-S10S10G44
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 1,368
