Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
LG LX160 Back Casing Replacement
Neye ihtiyacın var
  1. LG LX160 Back Casing Replacement, Battery: adım 1, 1 resimden 1.
    • Place the phone on a flat surface with the back facing upward.
    • Remove the back panel by placing your thumb on the LG logo and sliding the panel in a downward motion until the panel is removed.
  2. LG LX160 Back Casing Replacement: adım 2, 1 resimden 1.
    • Once the panel is removed, you will see the battery. Remove the battery by sliding your finger into the notch where the LG logo was on the panel and lift the battery.
  3. LG LX160 Back Casing Replacement: adım 3, 1 resimden 1.
    • Remove the battery completely from the phone and place the battery off to the side.
  4. LG LX160 Back Casing Replacement, Back Casing: adım 4, 1 resimden 1.
    • Before continuing pull off all the rubber tabs to the headphones, and the power input.
  5. LG LX160 Back Casing Replacement: adım 5, 1 resimden 1.
    • Now turn the phone so that you can see the back where the battery was. Using a screw driver, unscrew the 6 screws holding the back casing together.
  6. LG LX160 Back Casing Replacement: adım 6, 1 resimden 1.
    • At the top of the logic board there is a small rectangle with a white pad on it, use your tweezers and gently grip the neck of the orange wire.
    • Gently pull up on the orange wire until it comes loose. It may take some force so do not be concerned with being overly gentle.
Sonuç
Shane Smith
1 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-2, Forte Winter 2010 Cal Poly, Team 11-2, Forte Winter 2010 üyesi
CPSU-FORTE-W10S11G2
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,931
