Ana içeriğe geç
LG LX160 Front Casing Replacement
Neye ihtiyacın var
  1. LG LX160 Front Casing Replacement, Battery: adım 1, 1 resimden 1.
    • Place the phone on a flat surface with the back facing upward.
    • Remove the back panel by placing your thumb on the LG logo and sliding the panel in a downward motion until the panel is removed.
  2. LG LX160 Front Casing Replacement: adım 2, 1 resimden 1.
    • Once the panel is removed, you will see the battery. Remove the battery by sliding your finger into the notch where the LG logo was on the panel and lift the battery.
  3. LG LX160 Front Casing Replacement: adım 3, 1 resimden 1.
    • Remove the battery completely from the phone and place the battery off to the side.
  4. LG LX160 Front Casing Replacement, Back Casing: adım 4, 1 resimden 1.
    • Now that the battery has been completely removed, hold the phone upright.
    • Pull off all rubber tabs covering the headphone jack and the power input port. Do this before continuing the next steps.
  5. LG LX160 Front Casing Replacement: adım 5, 1 resimden 1.
    • Flip the phone with the backside facing up.
    • Using the Phillips #00 Screwdriver, unscrew the 6 screws that hold the back casing together.
  6. LG LX160 Front Casing Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Located at the top of the logic board there is a small rectangle with a white pad on it, use your tweezers and gently grip the neck of the orange wire.
    • Pull up gently on the orange wire until it comes loose. Do not be concerned with gentleness, it may require some force.
  7. LG LX160 Front Casing Replacement, Front Casing: adım 7, 1 resimden 1.
    • Open your phone to find four small rubber pads at each corner of the screen.
    • Remove each rubber piece and unscrew the screw under the rubber piece. You can see what the screw looks like under the rubber piece in the top right screw.
  8. LG LX160 Front Casing Replacement: adım 8, 1 resimden 1.
    • Use a splurger to slide in between the phone and the cover.
  9. LG LX160 Front Casing Replacement: adım 9, 1 resimden 1.
    • The cover will be separated from the phone and may be removed.
Sonuç
Kris Oznowic
1 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 11-2, Forte Winter 2010 Cal Poly, Team 11-2, Forte Winter 2010 üyesi
CPSU-FORTE-W10S11G2
5 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 2,088
