Giriş
If nothing seems to work when trying to fix your phone, then more than likely a new motherboard is all you need to fix your phone. This guide will show you how to replace your motherboard.
Neye ihtiyacın var
Place the phone on a flat surface with the back facing upward.
Remove the back panel by placing your thumb on the LG logo and sliding the panel in a downward motion until the panel is removed.
Before continuing pull off all the rubber tabs to the headphones, and the power input.
