Ana içeriğe geç
LG Lucid 4G LCD Replacement
Neye ihtiyacın var
  1. LG Lucid 4G LCD Replacement, Battery: adım 1, 3 resimden 1. LG Lucid 4G LCD Replacement, Battery: adım 1, 3 resimden 2. LG Lucid 4G LCD Replacement, Battery: adım 1, 3 resimden 3.
    • Turn off the phone by pressing the power button, then press "Power Off", then press "OK" when notified that your phone will shut down.
  2. LG Lucid 4G LCD Replacement: adım 2, 2 resimden 1. LG Lucid 4G LCD Replacement: adım 2, 2 resimden 2.
    • Flip the phone so that its back plate is facing upward.
    • Use your fingernail or prying tool to lift the back plate of the phone open by using the notch at the bottom.
  3. LG Lucid 4G LCD Replacement: adım 3, 2 resimden 1. LG Lucid 4G LCD Replacement: adım 3, 2 resimden 2.
    • Using the notch located near the bottom center, remove the battery with a prying tool or your fingernail.
  4. LG Lucid 4G LCD Replacement, LCD Assembly: adım 4, 2 resimden 1. LG Lucid 4G LCD Replacement, LCD Assembly: adım 4, 2 resimden 2.
    • Begin by removing the seven Phillip's head screws on the back of the phone.
  5. LG Lucid 4G LCD Replacement: adım 5, 2 resimden 1. LG Lucid 4G LCD Replacement: adım 5, 2 resimden 2.
    • Use the small notches along the sides of the phone to help you pry the back plate off and help stop the pry tool from slipping.
    • Use the plastic pry tool and begin working your way around the sides of the phone.
    • Some force may be required during this step.
  6. LG Lucid 4G LCD Replacement: adım 6, 1 resimden 1.
    • Remove the single Phillip's head screw holding the sim card assembly in place.
  7. LG Lucid 4G LCD Replacement: adım 7, 2 resimden 1. LG Lucid 4G LCD Replacement: adım 7, 2 resimden 2.
    • Gently lift the corner of the sim card assembly as shown.
    • The SIM card assembly is still attached to the motherboard via a ribbon cable.
    • Release the press-fit ribbon cable connector by lifting it with a spudger or prying tool.
  8. LG Lucid 4G LCD Replacement: adım 8, 2 resimden 1. LG Lucid 4G LCD Replacement: adım 8, 2 resimden 2.
    • Release the five flex connectors on the motherboard.
    • The camera may fall off during this step. That is okay! Set it aside for reassembly.
    • Once all five flex connectors are released, simply lift the motherboard to separate it from the rest of the phone.
  9. LG Lucid 4G LCD Replacement: adım 9, 1 resimden 1.
    • If the camera did not fall off during step five, you must remove it now by gently lifting it. It is attached by a small amount of adhesive and should detach easily.
    • Gently lift the headphone jack assembly to reveal the touch screen digitizer flex cable.
    • Release the touch screen digitizer flex cable connector.
  10. LG Lucid 4G LCD Replacement: adım 10, 2 resimden 1. LG Lucid 4G LCD Replacement: adım 10, 2 resimden 2.
    • Use a plastic pry tool to begin removing the touch screen assembly.
    • Slide the pry tool along the gap between the touch screen digitizer and the LCD mount to release the connectors.
    • Once the touch screen assembly has been separated, carefully slide the ribbon through the slot in its housing.
    • Caution: Be gentle when separating the two sections along the top of the phone. The ribbon detached in step 6 is attached to the touch screen digitizer and must be carefully fed through the LCD housing to avoid tearing it.
  11. LG Lucid 4G LCD Replacement: adım 11, 2 resimden 1. LG Lucid 4G LCD Replacement: adım 11, 2 resimden 2.
    • The final step is to remove the LCD screen from its housing. Begin by gently peeling the ribbon from the back of the housing.
    • Once the ribbon is fully detached, carefully feed it through the bottom of the display housing.
    • Once this is done the LCD screen assembly will have been separated from the phone.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Adam Boeck
133 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-1, Wilder Spring 2017 Ohio State, Team 1-1, Wilder Spring 2017 üyesi
OSU-WILDER-S17S1G1
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 8
Son 30 gün: 12
Her zaman: 332
