Ana içeriğe geç
LG Lucid 4G SIM Card Replacement
Neye ihtiyacın var
  1. LG Lucid 4G SIM Card Replacement, Battery: adım 1, 3 resimden 1. LG Lucid 4G SIM Card Replacement, Battery: adım 1, 3 resimden 2. LG Lucid 4G SIM Card Replacement, Battery: adım 1, 3 resimden 3.
    • Turn off the phone by pressing the power button, then press "Power Off", then press "OK" when notified that your phone will shut down.
  2. LG Lucid 4G SIM Card Replacement: adım 2, 2 resimden 1. LG Lucid 4G SIM Card Replacement: adım 2, 2 resimden 2.
    • Flip the phone so that its back plate is facing upward.
    • Use your fingernail or prying tool to lift the back plate of the phone open by using the notch at the bottom.
  3. LG Lucid 4G SIM Card Replacement: adım 3, 2 resimden 1. LG Lucid 4G SIM Card Replacement: adım 3, 2 resimden 2.
    • Using the notch located near the bottom center, remove the battery with a prying tool or your fingernail.
  4. LG Lucid 4G SIM Card Replacement, SIM Card: adım 4, 1 resimden 1.
    • After you have cleaned the battery area, locate the SIM card slot.
  5. LG Lucid 4G SIM Card Replacement: adım 5, 1 resimden 1.
    • Using your finger, carefully remove the SIM card from its slot by moving it toward the battery area.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Margaret Huck
219 İtibar
2 adet Kılavuz yazıldı
Ekip
Ohio State, Team 1-1, Wilder Spring 2017 Ohio State, Team 1-1, Wilder Spring 2017 üyesi
OSU-WILDER-S17S1G1
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 13
Her zaman: 332
