Giriş
Replacing the rear facing camera that is malfunctioning or has a cracked lens and is unusable.
  1. Use a plastic opening tool to remove the back cover.
    • Use a plastic opening tool to remove the back cover.
  2. Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
    • Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
  3. Use a Phillips #00 Screwdriver to remove all eight 4mm screws.
    • Use a Phillips #00 Screwdriver to remove all eight 4mm screws.
  4. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Use a plastic opening tool to remove the back trim by working around all of the edges. Use a plastic opening tool to remove the back trim by working around all of the edges.
    • Use a plastic opening tool to remove the back trim by working around all of the edges.
  6. Remove the volume buttons from the side. Remove the volume buttons from the side.
    • Remove the volume buttons from the side.
  7. Use a plastic opening tool to lift the speaker off by prying under the silver square as shown. Note: There is a small tab underneath the speaker that will be lifted off when the speaker is removed.
    • Use a plastic opening tool to lift the speaker off by prying under the silver square as shown.
    • Note: There is a small tab underneath the speaker that will be lifted off when the speaker is removed.
  8. Pry slightly underneath the tab attached to the camera until it pops off.
    • Pry slightly underneath the tab attached to the camera until it pops off.
  9. Use tweezers to remove the camera, you will need to use some force as it is glued on.
    • Use tweezers to remove the camera, you will need to use some force as it is glued on.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Zarna Patel
305 İtibar
2 adet Kılavuz yazıldı
Takım
USF Tampa, Team 14-1, Leahy Fall 2014 USF Tampa, Team 14-1, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S14G1
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 160
