Ana içeriğe geç
LG Muziq LX570 Camera Replacement
Neye ihtiyacın var
    1. LG Muziq LX570 Camera Replacement, Front Case: adım 1, 2 resimden 1. LG Muziq LX570 Camera Replacement, Front Case: adım 1, 2 resimden 2.
      • Use a spudger to remove the two screw covers below display.
      • Use a screw driver to remove the four Phillips #00 (3.3mm) screws at corners of the display.
      FixBot'a Sor
      Yorum Ekle
    2. LG Muziq LX570 Camera Replacement: adım 2, 3 resimden 1. LG Muziq LX570 Camera Replacement: adım 2, 3 resimden 2. LG Muziq LX570 Camera Replacement: adım 2, 3 resimden 3.
      • Caution: Wires and ribbon connect the front case to the main body. Exhibit care when separating front case from the main body as to not break the connections.
      • Note: Side buttons may fall out when removing the front case. Do not misplace them.
      • Note: Each side button will only fit in the side that it came from.
      • Insert a spudger between the black and grey casings and gently spread them apart.
      • Work around the device gradually, opening the gap further.
      FixBot'a Sor
      Yorum Ekle
    3. LG Muziq LX570 Camera Replacement: adım 3, 3 resimden 1. LG Muziq LX570 Camera Replacement: adım 3, 3 resimden 2. LG Muziq LX570 Camera Replacement: adım 3, 3 resimden 3.
      • Caution: The wires and ribbon connector can break easily. Exhibit care when removing them.
      • Use the spudger and lift upward to disconnect the ribbon from the main part of the phone.
      • Carefully remove any parts stuck to the front case such as speakers.
      FixBot'a Sor
      Yorum Ekle
    1. LG Muziq LX570 Camera Replacement, Camera: adım 4, 3 resimden 1. LG Muziq LX570 Camera Replacement, Camera: adım 4, 3 resimden 2. LG Muziq LX570 Camera Replacement, Camera: adım 4, 3 resimden 3.
      • Disconnect the ribbons on both sides of the camera by prying them up with a spudger.
      FixBot'a Sor
      Yorum Ekle
    2. LG Muziq LX570 Camera Replacement: adım 5, 2 resimden 1. LG Muziq LX570 Camera Replacement: adım 5, 2 resimden 2.
      • Hold the wiring out of the way and pull up with a spudger behind the camera.
      • The camera unit should come unglued and separate from the phone.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Braden Burk
1 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-29, Amido Winter 2012 Cal Poly, Team 3-29, Amido Winter 2012 üyesi
CPSU-AMIDO-W12S3G29
4 Üyeler
49 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 1,016
