Giriş
This guide will assist you in replacing your phone's faulty camera.
Neye ihtiyacın var
Use a spudger to remove the two screw covers below display.
Use a screw driver to remove the four Phillips #00 (3.3mm) screws at corners of the display.
Note: Side buttons may fall out when removing the front case. Do not misplace them.
Note: Each side button will only fit in the side that it came from.
Insert a spudger between the black and grey casings and gently spread them apart.
Work around the device gradually, opening the gap further.
Disconnect the ribbons on both sides of the camera by prying them up with a spudger.
