Ana içeriğe geç
LG Muziq LX570 Display Panel Replacement
Neye ihtiyacın var
  1. LG Muziq LX570 Display Panel Replacement, Front Case: adım 1, 2 resimden 1. LG Muziq LX570 Display Panel Replacement, Front Case: adım 1, 2 resimden 2.
    • Use a spudger to remove the two screw covers below display.
    • Use a screw driver to remove the four Phillips #00 (3.3mm) screws at corners of the display.
    FixBot'a Sor
    Yorum Ekle
  2. LG Muziq LX570 Display Panel Replacement: adım 2, 3 resimden 1. LG Muziq LX570 Display Panel Replacement: adım 2, 3 resimden 2. LG Muziq LX570 Display Panel Replacement: adım 2, 3 resimden 3.
    • Caution: Wires and ribbon connect the front case to the main body. Exhibit care when separating front case from the main body as to not break the connections.
    • Note: Side buttons may fall out when removing the front case. Do not misplace them.
    • Note: Each side button will only fit in the side that it came from.
    • Insert a spudger between the black and grey casings and gently spread them apart.
    • Work around the device gradually, opening the gap further.
    FixBot'a Sor
    Yorum Ekle
  3. LG Muziq LX570 Display Panel Replacement: adım 3, 3 resimden 1. LG Muziq LX570 Display Panel Replacement: adım 3, 3 resimden 2. LG Muziq LX570 Display Panel Replacement: adım 3, 3 resimden 3.
    • Caution: The wires and ribbon connector can break easily. Exhibit care when removing them.
    • Use the spudger and lift upward to disconnect the ribbon from the main part of the phone.
    • Carefully remove any parts stuck to the front case such as speakers.
    FixBot'a Sor
    Yorum Ekle
  4. LG Muziq LX570 Display Panel Replacement, Display Panel: adım 4, 3 resimden 1. LG Muziq LX570 Display Panel Replacement, Display Panel: adım 4, 3 resimden 2. LG Muziq LX570 Display Panel Replacement, Display Panel: adım 4, 3 resimden 3.
    • Use the spudger to unclip the two upper wiring connections.
    FixBot'a Sor
    Yorum Ekle
  5. LG Muziq LX570 Display Panel Replacement: adım 5, 2 resimden 1. LG Muziq LX570 Display Panel Replacement: adım 5, 2 resimden 2.
    • Caution: The side buttons are attached to the ribbon around the display screen. Do not separate the side buttons from the ribbon when removing.
    • Gently lift the side buttons from the phone casing.
    FixBot'a Sor
    Yorum Ekle
  6. LG Muziq LX570 Display Panel Replacement: adım 6, 3 resimden 1. LG Muziq LX570 Display Panel Replacement: adım 6, 3 resimden 2. LG Muziq LX570 Display Panel Replacement: adım 6, 3 resimden 3.
    • Caution: The wiring on the ribbon connector is delicate. Do not excessively pull on the wires.
    • Use the spudger to remove the three components connected to the ribbon.
    FixBot'a Sor
    Yorum Ekle
  7. LG Muziq LX570 Display Panel Replacement: adım 7, 3 resimden 1. LG Muziq LX570 Display Panel Replacement: adım 7, 3 resimden 2. LG Muziq LX570 Display Panel Replacement: adım 7, 3 resimden 3.
    • Caution: The ribbon contains important wiring and is glued to the phone. Be careful when removing the ribbon.
    • Use the spudger to gently remove the ribbon from the phone.
    FixBot'a Sor
    Yorum Ekle
  8. LG Muziq LX570 Display Panel Replacement: adım 8, 3 resimden 1. LG Muziq LX570 Display Panel Replacement: adım 8, 3 resimden 2. LG Muziq LX570 Display Panel Replacement: adım 8, 3 resimden 3.
    • Use the spudger to lift the upper tab in the top left corner of the display.
    • Continue lifting until the display panels lift out of their setting and can be removed.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Braden Burk
1 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-29, Amido Winter 2012 Cal Poly, Team 3-29, Amido Winter 2012 üyesi
CPSU-AMIDO-W12S3G29
4 Üyeler
27 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 37
Her zaman: 1,341
