Ana içeriğe geç
LG Muziq LX570 Front Case Replacement
Neye ihtiyacın var
  1. LG Muziq LX570 Front Case Replacement, Front Case: adım 1, 2 resimden 1. LG Muziq LX570 Front Case Replacement, Front Case: adım 1, 2 resimden 2.
    • Use a spudger to remove the two screw covers below display.
    • Use a screw driver to remove the four Phillips #00 (3.3mm) screws at corners of the display.
  2. LG Muziq LX570 Front Case Replacement: adım 2, 3 resimden 1. LG Muziq LX570 Front Case Replacement: adım 2, 3 resimden 2. LG Muziq LX570 Front Case Replacement: adım 2, 3 resimden 3.
    • Caution: Wires and ribbon connect the front case to the main body. Exhibit care when separating front case from the main body as to not break the connections.
    • Note: Side buttons may fall out when removing the front case. Do not misplace them.
    • Note: Each side button will only fit in the side that it came from.
    • Insert a spudger between the black and grey casings and gently spread them apart.
    • Work around the device gradually, opening the gap further.
  3. LG Muziq LX570 Front Case Replacement: adım 3, 3 resimden 1. LG Muziq LX570 Front Case Replacement: adım 3, 3 resimden 2. LG Muziq LX570 Front Case Replacement: adım 3, 3 resimden 3.
    • Caution: The wires and ribbon connector can break easily. Exhibit care when removing them.
    • Use the spudger and lift upward to disconnect the ribbon from the main part of the phone.
    • Carefully remove any parts stuck to the front case such as speakers.
Sonuç
Raymond Ching
1 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 3-29, Amido Winter 2012 Cal Poly, Team 3-29, Amido Winter 2012 üyesi
CPSU-AMIDO-W12S3G29
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 571
