Ana içeriğe geç
LG Muziq LX570 Keypad Replacement
Neye ihtiyacın var
  1. LG Muziq LX570 Keypad Replacement, Battery: adım 1, 2 resimden 1. LG Muziq LX570 Keypad Replacement, Battery: adım 1, 2 resimden 2.
    • Slide the battery cover release towards top of phone.
    • Place one finger at each side of the battery cover.
    • Lift and remove the battery cover.
    FixBot'a Sor
    Yorum Ekle
  2. LG Muziq LX570 Keypad Replacement: adım 2, 2 resimden 1. LG Muziq LX570 Keypad Replacement: adım 2, 2 resimden 2.
    • Place a finger at the top corner of the battery and lift out of the phone.
    FixBot'a Sor
    Yorum Ekle
  3. LG Muziq LX570 Keypad Replacement, Rear Case: adım 3, 2 resimden 1. LG Muziq LX570 Keypad Replacement, Rear Case: adım 3, 2 resimden 2.
    • Use the spudger to lift up the two screw covers at the top of the phone.
    • Remove all four Phillips#00 (3.3mm) screws with screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. LG Muziq LX570 Keypad Replacement: adım 4, 3 resimden 1. LG Muziq LX570 Keypad Replacement: adım 4, 3 resimden 2. LG Muziq LX570 Keypad Replacement: adım 4, 3 resimden 3.
    • Use the spudger to lift up the rear case from the phone.
    • Note: Rear case is connected on all sides and will have to be detached on all sides before removal.
    • Remove the rear case from the device.
    FixBot'a Sor
    Yorum Ekle
  5. LG Muziq LX570 Keypad Replacement, Motherboard: adım 5, 3 resimden 1. LG Muziq LX570 Keypad Replacement, Motherboard: adım 5, 3 resimden 2. LG Muziq LX570 Keypad Replacement, Motherboard: adım 5, 3 resimden 3.
    • Use the spudger to lift the motherboard from the phone.
    FixBot'a Sor
    Yorum Ekle
  6. LG Muziq LX570 Keypad Replacement, Keypad: adım 6, 3 resimden 1. LG Muziq LX570 Keypad Replacement, Keypad: adım 6, 3 resimden 2. LG Muziq LX570 Keypad Replacement, Keypad: adım 6, 3 resimden 3.
    • Caution: The circuit board is connected via ribbon to the phone. Do not break this connection.
    • Note: The circuit board is attached by clips on both sides of the board. Detach each clip before removing the motherboard from the phone.
    • Use the spudger to detach the circuit board from the phone.
    FixBot'a Sor
    Yorum Ekle
  7. LG Muziq LX570 Keypad Replacement: adım 7, 3 resimden 1. LG Muziq LX570 Keypad Replacement: adım 7, 3 resimden 2. LG Muziq LX570 Keypad Replacement: adım 7, 3 resimden 3.
    • Open the phone to expose the keypad.
    • Use your finger to push the keypad from the front towards the circuit board.
    • Remove the keypad from the phone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Braden Burk
1 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-29, Amido Winter 2012 Cal Poly, Team 3-29, Amido Winter 2012 üyesi
CPSU-AMIDO-W12S3G29
4 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 29
Her zaman: 984
