Ana içeriğe geç
LG Muziq LX570 Rear Case Replacement
Neye ihtiyacın var
  1. LG Muziq LX570 Rear Case Replacement, Battery: adım 1, 2 resimden 1. LG Muziq LX570 Rear Case Replacement, Battery: adım 1, 2 resimden 2.
    • Slide the battery cover release towards top of phone.
    • Place one finger at each side of the battery cover.
    • Lift and remove the battery cover.
  2. LG Muziq LX570 Rear Case Replacement: adım 2, 2 resimden 1. LG Muziq LX570 Rear Case Replacement: adım 2, 2 resimden 2.
    • Place a finger at the top corner of the battery and lift out of the phone.
  3. LG Muziq LX570 Rear Case Replacement, Rear Case: adım 3, 2 resimden 1. LG Muziq LX570 Rear Case Replacement, Rear Case: adım 3, 2 resimden 2.
    • Use the spudger to lift up the two screw covers at the top of the phone.
    • Remove all four Phillips#00 (3.3mm) screws with screwdriver.
  4. LG Muziq LX570 Rear Case Replacement: adım 4, 3 resimden 1. LG Muziq LX570 Rear Case Replacement: adım 4, 3 resimden 2. LG Muziq LX570 Rear Case Replacement: adım 4, 3 resimden 3.
    • Use the spudger to lift up the rear case from the phone.
    • Note: Rear case is connected on all sides and will have to be detached on all sides before removal.
    • Remove the rear case from the device.
Sonuç
Matthew Cataldo
1 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 3-29, Amido Winter 2012 Cal Poly, Team 3-29, Amido Winter 2012 üyesi
CPSU-AMIDO-W12S3G29
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 541
