Ana içeriğe geç
LG Optimus Dynamic II L39C Camera Replacement
Neye ihtiyacın var
  1. LG Optimus Dynamic II L39C Camera Replacement, Remove the back case: adım 1, 2 resimden 1. LG Optimus Dynamic II L39C Camera Replacement, Remove the back case: adım 1, 2 resimden 2.
    • Make sure not to push the tool into the USB port. Doing so may cause damage to your phone.
    • Hold the blue plastic opening tool at the edge of the USB opening. Push down and pry the case off the phone gently.
  2. LG Optimus Dynamic II L39C Camera Replacement, Remove the Battery: adım 2, 1 resimden 1.
    • Lift the battery out of the phone and replace with your new one.
  3. LG Optimus Dynamic II L39C Camera Replacement, Remove the SD Card: adım 3, 1 resimden 1.
    • Grab the end of the SD Card and pull it out of the phone.
  4. LG Optimus Dynamic II L39C Camera Replacement, Remove the screws from the midframe: adım 4, 2 resimden 1. LG Optimus Dynamic II L39C Camera Replacement, Remove the screws from the midframe: adım 4, 2 resimden 2.
    • Use the PH #000 screwdriver to remove the six screws from the midframe
  5. LG Optimus Dynamic II L39C Camera Replacement, Remove the midframe: adım 5, 2 resimden 1. LG Optimus Dynamic II L39C Camera Replacement, Remove the midframe: adım 5, 2 resimden 2.
    • Using the plastic opening tool, work gently to go around the perimeter of the phone and remove the midframe.
  6. LG Optimus Dynamic II L39C Camera Replacement, Disconnect the screen from the motherboard: adım 6, 3 resimden 1. LG Optimus Dynamic II L39C Camera Replacement, Disconnect the screen from the motherboard: adım 6, 3 resimden 2. LG Optimus Dynamic II L39C Camera Replacement, Disconnect the screen from the motherboard: adım 6, 3 resimden 3.
    • Use the plastic opening tool to disconnect the small orange tab from the motherboard.
    • Next disconnect the silver tab slightly above where the orange tab was.
  7. LG Optimus Dynamic II L39C Camera Replacement, Separate the screen and motherboard: adım 7, 1 resimden 1.
    • Gently feed the orange and silver tabbed ribbons through the hole in the motherboard and the screen will be free.
  8. LG Optimus Dynamic II L39C Camera Replacement, Detach tabs to separate the camera: adım 8, 2 resimden 1. LG Optimus Dynamic II L39C Camera Replacement, Detach tabs to separate the camera: adım 8, 2 resimden 2.
    • Using the spudger, push the black tabs on the sides of the motherboard off carefully.
    • They should snap off easily.
  9. LG Optimus Dynamic II L39C Camera Replacement, Separate orange tab: adım 9, 1 resimden 1.
    • Turn the phone over and pull up the orange tab connected to the camera.
  10. LG Optimus Dynamic II L39C Camera Replacement, Separate the camera from the motherboard: adım 10, 2 resimden 1. LG Optimus Dynamic II L39C Camera Replacement, Separate the camera from the motherboard: adım 10, 2 resimden 2.
    • You should be able to remove the camera easily with your fingers.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Stephanie Reyes
138 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-3, Leahy Fall 2014 USF Tampa, Team 14-3, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S14G3
4 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 30
Her zaman: 466
