Ana içeriğe geç
LG Optimus Exceed 2 Motherboard Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. LG Optimus Exceed 2 Motherboard Replacement, Battery: adım 1, 2 resimden 1. LG Optimus Exceed 2 Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the device over and remove the back covering.
  2. LG Optimus Exceed 2 Motherboard Replacement: adım 2, 1 resimden 1.
    • Push on the top of the battery downward and pull the battery off of the device.
  3. LG Optimus Exceed 2 Motherboard Replacement, Rear Camera: adım 3, 3 resimden 1. LG Optimus Exceed 2 Motherboard Replacement, Rear Camera: adım 3, 3 resimden 2. LG Optimus Exceed 2 Motherboard Replacement, Rear Camera: adım 3, 3 resimden 3.
    • Remove the eleven 4mm screws using a Philips head screw driver.
  4. LG Optimus Exceed 2 Motherboard Replacement: adım 4, 3 resimden 1. LG Optimus Exceed 2 Motherboard Replacement: adım 4, 3 resimden 2. LG Optimus Exceed 2 Motherboard Replacement: adım 4, 3 resimden 3.
    • Insert the plastic opening tool into the side of the device and pry off silver covering. Push up against the back covering when the tool is inserted to detach from the phone.
    • Make sure to detach all sides of silver covering before lifting it off the phone.
  5. LG Optimus Exceed 2 Motherboard Replacement: adım 5, 2 resimden 1. LG Optimus Exceed 2 Motherboard Replacement: adım 5, 2 resimden 2.
    • Using the prying tool detach the connector on the device.
    • Insert the plastic opening tool underneath the connector and push tool down to lift the connector from the device.
  6. LG Optimus Exceed 2 Motherboard Replacement: adım 6, 2 resimden 1. LG Optimus Exceed 2 Motherboard Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using tweezers lift the camera off of the device.
    • To do so grasp the camera gently with the tweezers and pull the camera up out of the device.
  7. LG Optimus Exceed 2 Motherboard Replacement, Motherboard: adım 7, 2 resimden 1. LG Optimus Exceed 2 Motherboard Replacement, Motherboard: adım 7, 2 resimden 2.
    • Disconnect the remaining ribbon plugs and connectors. (Only remove the highlighted cables for the removal of the logic board.)
  8. LG Optimus Exceed 2 Motherboard Replacement: adım 8, 2 resimden 1. LG Optimus Exceed 2 Motherboard Replacement: adım 8, 2 resimden 2.
    • Push the blue lifting tool up underneath the logic board and pull it upwards removing it from the device.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Carl Dorvilus
708 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-4, Catania Spring 2016 UMass Dartmouth, Team 4-4, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S4G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 15
Son 30 gün: 15
Her zaman: 541
