Giriş
If the SD card exceeds its memory capacity, use this guide to replace the SD card
When the back cover is completely removed, locate the sim card slot. It should be to the right of the camera and it is clearly labeled “Micro SD”
You should now be able to put in a new SD card in that same slot.
2 farklı kişi bu kılavuzu tamamladı.
