Ana içeriğe geç
LG Optimus F3 digitizer screen glass replacement
Neye ihtiyacın var
  1. LG Optimus F3 digitizer screen glass replacement, Digitzer Glass: adım 1, 3 resimden 1. LG Optimus F3 digitizer screen glass replacement, Digitzer Glass: adım 1, 3 resimden 2. LG Optimus F3 digitizer screen glass replacement, Digitzer Glass: adım 1, 3 resimden 3.
    • Remove Back Cover
    • Remove SDCard (if you have one)
    • Remove SIM Card
    • Remove Battery
  2. LG Optimus F3 digitizer screen glass replacement: adım 2, 2 resimden 1. LG Optimus F3 digitizer screen glass replacement: adım 2, 2 resimden 2.
    • Remove 10 Philips Head screws
  3. LG Optimus F3 digitizer screen glass replacement: adım 3, 2 resimden 1. LG Optimus F3 digitizer screen glass replacement: adım 3, 2 resimden 2.
    • Using a pry took, pry the back plate off of the phone. Work your way around, prying the tabs as you come to them.
  4. LG Optimus F3 digitizer screen glass replacement: adım 4, 2 resimden 1. LG Optimus F3 digitizer screen glass replacement: adım 4, 2 resimden 2.
    • Use pry tool to disconnect camera cable and then remove the camera
  5. LG Optimus F3 digitizer screen glass replacement: adım 5, 2 resimden 1. LG Optimus F3 digitizer screen glass replacement: adım 5, 2 resimden 2.
    • Use pry tool to disconnect 4 ribbon cables and two antenna wires.
  6. LG Optimus F3 digitizer screen glass replacement: adım 6, 2 resimden 1. LG Optimus F3 digitizer screen glass replacement: adım 6, 2 resimden 2.
    • Use pry tool to gently remove the logic board.
  7. LG Optimus F3 digitizer screen glass replacement: adım 7, 2 resimden 1. LG Optimus F3 digitizer screen glass replacement: adım 7, 2 resimden 2.
    • Use pry tool to remove headphone jack.
  8. LG Optimus F3 digitizer screen glass replacement: adım 8, 1 resimden 1.
    • Use the pry tool to pry the front frame off of the main body of the phone.
  9. LG Optimus F3 digitizer screen glass replacement: adım 9, 1 resimden 1.
    • Carefully pull the digitizer cable through the slot. There will be a small piece of rubber blocking the opening. You may remove it, or just pull through it.
    • Note: If the slot is not wide enough, make sure that you removed the headphone jack, as described in step 7.
  10. LG Optimus F3 digitizer screen glass replacement: adım 10, 1 resimden 1.
    • Use a heat gun or blow dryer to heat up the adhesive holding the glass in the frame. Carefully remove the glass using a pry tool.
    • Clean existing adhesive off of frame, or reuse it if you managed to keep it intact.
    • Apply new adhesive if not reusing existing adhesive.
    • Insert new glass.
    • Ensure that speaker cover at top of phone is in place.
    • Reverse steps to reassemble phone.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Rita Snodgrass
284 İtibar
1 Kılavuz yazıldı
3 Yorum
I followed the guide, put it back together but it now starts up and only stays up for a bit before reporting a heating issue. It feels hot in the upper left hand corner of the phone as well as the back upper middle.
any thoughts on what I did wrong?
chris baggett - Yanıt
I did this repair successfully, and linked to an album of photos below. I actually took these photos while putting it back together, but I reversed the order to help with taking it apart.
http://imgur.com/a/sRfRM
There's a couple things to watch out for.
First - there's two versions of the screen for the LG Optimus F3. You either have the (LS720/MS659/VM720) screen, which has rounded corners at the top (like mine), or the (MS659/P659), which has square corners at the top. I bought the wrong one, and cracked it trying to grind the corners off at the top.
You will need to use a heat gun to get the old screen off, and I just used an epoxy to attach the new one.
When reassembling, make sure all of your wires are plugged back in. I missed one, and I was getting no signal. Last thing - make sure you put the main center button in before you snap the front screen assembly to the main phone body.
James - Yanıt
screen replaced. phone turns on
yet device touch screen does not work.
Anthony - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 7,542
