Ana içeriğe geç
LG Optimus F60 Front Camera Replacement
Neye ihtiyacın var
    1. LG Optimus F60 Front Camera Replacement, Battery: adım 1, 3 resimden 1. LG Optimus F60 Front Camera Replacement, Battery: adım 1, 3 resimden 2. LG Optimus F60 Front Camera Replacement, Battery: adım 1, 3 resimden 3.
      • Hold the phone in your hand and position the small plastic opening tool or your finger under the lip of the phone by the USB port.
      • Pry or lift up on the indent with the opening tool.
      • Remove the back panel.
      FixBot'a Sor
      Yorum Ekle
    2. LG Optimus F60 Front Camera Replacement: adım 2, 3 resimden 1. LG Optimus F60 Front Camera Replacement: adım 2, 3 resimden 2. LG Optimus F60 Front Camera Replacement: adım 2, 3 resimden 3.
      • Place the small plastic opening tool or your finger at the indentation at the base of the battery.
      • Pry upwards or lift with your finger and remove battery.
      FixBot'a Sor
      Yorum Ekle
    1. LG Optimus F60 Front Camera Replacement, Front Camera: adım 3, 2 resimden 1. LG Optimus F60 Front Camera Replacement, Front Camera: adım 3, 2 resimden 2.
      • Use the phillips #000 Screwdriver to unscrew eight 4mm screws.
      FixBot'a Sor
      Yorum Ekle
    2. LG Optimus F60 Front Camera Replacement: adım 4, 2 resimden 1. LG Optimus F60 Front Camera Replacement: adım 4, 2 resimden 2.
      • Insert the plastic opening tool in the indentation marked by the red square.
      • Pry the plastic opening tool upwards to release the lower back panel.
      • Remove the lower back panel from the device.
      FixBot'a Sor
      Yorum Ekle
    3. LG Optimus F60 Front Camera Replacement: adım 5, 3 resimden 1. LG Optimus F60 Front Camera Replacement: adım 5, 3 resimden 2. LG Optimus F60 Front Camera Replacement: adım 5, 3 resimden 3.
      • Continue moving plastic opening tool around device until back panel is loose enough to remove.
      FixBot'a Sor
      Yorum Ekle
    4. LG Optimus F60 Front Camera Replacement: adım 6, 3 resimden 1. LG Optimus F60 Front Camera Replacement: adım 6, 3 resimden 2. LG Optimus F60 Front Camera Replacement: adım 6, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Locate the digitizer connection on the lower left hand side of the device.
      • Use the tweezers to lift up and gently remove the connector.
      FixBot'a Sor
      Yorum Ekle
    5. LG Optimus F60 Front Camera Replacement: adım 7, 3 resimden 1. LG Optimus F60 Front Camera Replacement: adım 7, 3 resimden 2. LG Optimus F60 Front Camera Replacement: adım 7, 3 resimden 3.
      • Locate the front camera on the upper left hand side of the device. The camera is marked in red.
      • Use the tweezers to remove the front camera from the connector marked in orange.
      • Remove and replace front camera.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Austin Johnson
171 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 23
Her zaman: 492
