Ana içeriğe geç
LG Optimus F60 Front Camera Replacement
Neye ihtiyacın var
  1. LG Optimus F60 Front Camera Replacement, Battery: adım 1, 3 resimden 1. LG Optimus F60 Front Camera Replacement, Battery: adım 1, 3 resimden 2. LG Optimus F60 Front Camera Replacement, Battery: adım 1, 3 resimden 3.
    • Hold the phone in your hand and position the small plastic opening tool or your finger under the lip of the phone by the USB port.
    • Pry or lift up on the indent with the opening tool.
    • Remove the back panel.
  2. LG Optimus F60 Front Camera Replacement: adım 2, 3 resimden 1. LG Optimus F60 Front Camera Replacement: adım 2, 3 resimden 2. LG Optimus F60 Front Camera Replacement: adım 2, 3 resimden 3.
    • Place the small plastic opening tool or your finger at the indentation at the base of the battery.
    • Pry upwards or lift with your finger and remove battery.
  3. LG Optimus F60 Front Camera Replacement, Front Camera: adım 3, 2 resimden 1. LG Optimus F60 Front Camera Replacement, Front Camera: adım 3, 2 resimden 2.
    • Use the phillips #000 Screwdriver to unscrew eight 4mm screws.
  4. LG Optimus F60 Front Camera Replacement: adım 4, 2 resimden 1. LG Optimus F60 Front Camera Replacement: adım 4, 2 resimden 2.
    • Insert the plastic opening tool in the indentation marked by the red square.
    • Pry the plastic opening tool upwards to release the lower back panel.
    • Remove the lower back panel from the device.
  5. LG Optimus F60 Front Camera Replacement: adım 5, 3 resimden 1. LG Optimus F60 Front Camera Replacement: adım 5, 3 resimden 2. LG Optimus F60 Front Camera Replacement: adım 5, 3 resimden 3.
    • Continue moving plastic opening tool around device until back panel is loose enough to remove.
  6. LG Optimus F60 Front Camera Replacement: adım 6, 3 resimden 1. LG Optimus F60 Front Camera Replacement: adım 6, 3 resimden 2. LG Optimus F60 Front Camera Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Locate the digitizer connection on the lower left hand side of the device.
    • Use the tweezers to lift up and gently remove the connector.
  7. LG Optimus F60 Front Camera Replacement: adım 7, 3 resimden 1. LG Optimus F60 Front Camera Replacement: adım 7, 3 resimden 2. LG Optimus F60 Front Camera Replacement: adım 7, 3 resimden 3.
    • Locate the front camera on the upper left hand side of the device. The camera is marked in red.
    • Use the tweezers to remove the front camera from the connector marked in orange.
    • Remove and replace front camera.
Sonuç
Austin Johnson
171 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 226
