Ana içeriğe geç
LG Optimus F60 Screen Replacement
Neye ihtiyacın var
  1. LG Optimus F60 Screen Replacement, Battery: adım 1, 3 resimden 1. LG Optimus F60 Screen Replacement, Battery: adım 1, 3 resimden 2. LG Optimus F60 Screen Replacement, Battery: adım 1, 3 resimden 3.
    • Hold the phone in your hand and position the small plastic opening tool or your finger under the lip of the phone by the USB port.
    • Pry or lift up on the indent with the opening tool.
    • Remove the back panel.
  2. LG Optimus F60 Screen Replacement: adım 2, 3 resimden 1. LG Optimus F60 Screen Replacement: adım 2, 3 resimden 2. LG Optimus F60 Screen Replacement: adım 2, 3 resimden 3.
    • Place the small plastic opening tool or your finger at the indentation at the base of the battery.
    • Pry upwards or lift with your finger and remove battery.
  3. LG Optimus F60 Screen Replacement, Screen: adım 3, 1 resimden 1.
    • Remove the eight 4 mm screws on the inner panel using the phillips #000 Screwdriver
  4. LG Optimus F60 Screen Replacement: adım 4, 1 resimden 1.
    • Remove bottom of inner panel.
  5. LG Optimus F60 Screen Replacement: adım 5, 3 resimden 1. LG Optimus F60 Screen Replacement: adım 5, 3 resimden 2. LG Optimus F60 Screen Replacement: adım 5, 3 resimden 3.
    • Remove inner panel using plastic opening tool.
    • Apply force upwards while wiggling the tool further in.
  6. LG Optimus F60 Screen Replacement: adım 6, 3 resimden 1. LG Optimus F60 Screen Replacement: adım 6, 3 resimden 2. LG Optimus F60 Screen Replacement: adım 6, 3 resimden 3.
    • Unlatch Connector on bottom left of phone.
  7. LG Optimus F60 Screen Replacement: adım 7, 2 resimden 1. LG Optimus F60 Screen Replacement: adım 7, 2 resimden 2.
    • Pull motherboard to detach digitizer from the motherboard
Sonuç
Kayli Beidler
183 İtibar
1 Kılavuz yazıldı
Bir Yorum
The LG f60 digitizer replacement was difficult to find on internet as of Nov 2023. Luckily I found the right vendor.
The ifixit instructions and photos on this page were superb. I repaired the phone easily.
The only obstacle not in the instructions was the removal of the glass shards that were around the edge of the old frame that had to be picked off so that the digitizer could fit flat in the original frame.
Thanks for your site.
Victor Lewandowski - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 355
