Ana içeriğe geç
LG Optimus F60 Speaker Replacement
Neye ihtiyacın var
  1. LG Optimus F60 Speaker Replacement, Battery: adım 1, 3 resimden 1. LG Optimus F60 Speaker Replacement, Battery: adım 1, 3 resimden 2. LG Optimus F60 Speaker Replacement, Battery: adım 1, 3 resimden 3.
    • Hold the phone in your hand and position the small plastic opening tool or your finger under the lip of the phone by the USB port.
    • Pry or lift up on the indent with the opening tool.
    • Remove the back panel.
  2. LG Optimus F60 Speaker Replacement: adım 2, 3 resimden 1. LG Optimus F60 Speaker Replacement: adım 2, 3 resimden 2. LG Optimus F60 Speaker Replacement: adım 2, 3 resimden 3.
    • Place the small plastic opening tool or your finger at the indentation at the base of the battery.
    • Pry upwards or lift with your finger and remove battery.
  3. LG Optimus F60 Speaker Replacement, Speaker: adım 3, 3 resimden 1. LG Optimus F60 Speaker Replacement, Speaker: adım 3, 3 resimden 2. LG Optimus F60 Speaker Replacement, Speaker: adım 3, 3 resimden 3.
    • Use the Phillips #000 screwdriver to remove eight screws.
  4. LG Optimus F60 Speaker Replacement: adım 4, 2 resimden 1. LG Optimus F60 Speaker Replacement: adım 4, 2 resimden 2.
    • Insert the iFixit opening tool in the indentation.
    • Pry the plastic using the opening tool to remove the lower back panel.
    • Remove the back panel from the device.
  5. LG Optimus F60 Speaker Replacement: adım 5, 3 resimden 1. LG Optimus F60 Speaker Replacement: adım 5, 3 resimden 2. LG Optimus F60 Speaker Replacement: adım 5, 3 resimden 3.
    • Start at the changing port, and continue to pry at the edges until loose enough to remove.
  6. LG Optimus F60 Speaker Replacement: adım 6, 3 resimden 1. LG Optimus F60 Speaker Replacement: adım 6, 3 resimden 2. LG Optimus F60 Speaker Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Gently pry the foam seal from around the speaker.
    • Pry out speaker using tweezers.
    • Remove and replace the speaker.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Mohammad Mohammad
451 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G5, Henning Spring 2019 IUPUI, Team S2-G5, Henning Spring 2019 üyesi
IUPUI-HENNING-S19S2G5
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 97
