Ana içeriğe geç
LG Optimus G Pro Rear Facing Camera Replacement
Neye ihtiyacın var
  1. LG Optimus G Pro Rear Facing Camera Replacement, Remove Back Cover.: adım 1, 1 resimden 1.
    • Make sure before you begin working on your device, that the device is not charging.
    • Once you have access to the phone, there is a small indent on the bottom left side. Use your fingernail or a plastic opening tool to pry from here and pull off the back casing.
    FixBot'a Sor
    Yorum Ekle
  2. LG Optimus G Pro Rear Facing Camera Replacement, Remove the Battery.: adım 2, 1 resimden 1.
    • Once you have properly removed the outer casing, the back should look as so.
    • To remove the battery, pull up from the red mark using your finger. The battery should come up at an angle, and easily be able to be removed.
    • Once the battery is removed you may safely proceed to the next step.
    FixBot'a Sor
    Yorum Ekle
  3. LG Optimus G Pro Rear Facing Camera Replacement, Screw Removal: adım 3, 2 resimden 1. LG Optimus G Pro Rear Facing Camera Replacement, Screw Removal: adım 3, 2 resimden 2.
    • Make sure you remove the battery first. You will see that there are 14 screws on the back of the inner case. Use the Phillips head screwdriver to remove each of the screws, make sure to put the screws in a safe place where they will not get lost.
    FixBot'a Sor
    Yorum Ekle
  4. LG Optimus G Pro Rear Facing Camera Replacement, Remove Cover: adım 4, 1 resimden 1.
    • Once you have removed all the screws, you can begin removing the inside cover.
    • Insert the opening tool using a sliding motion into one of the corners and move it along the edges of the inside cover. This will loosen the edges and the inside cover will pry apart from the shell.
    FixBot'a Sor
    Yorum Ekle
  5. LG Optimus G Pro Rear Facing Camera Replacement, Completion: adım 5, 1 resimden 1.
    • The inner cover is now removed, you now have access to the many parts on the inside of the phone.
    FixBot'a Sor
    Yorum Ekle
  6. LG Optimus G Pro Rear Facing Camera Replacement, Remove the Ribbon Cable: adım 6, 1 resimden 1.
    • Using a plastic opening tool, pry the connection between the cable and the phone. With even pressure the cable should disconnect from the logic board easily.
    FixBot'a Sor
    Yorum Ekle
  7. LG Optimus G Pro Rear Facing Camera Replacement, Remove the Camera: adım 7, 1 resimden 1.
    • After removing the the Ribbon Cable, the Rear-Facing Camera should be able to be removed easily with your fingers.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Wesley Pate
1.641 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-5, Remmell Fall 2014 USF Tampa, Team 15-5, Remmell Fall 2014 üyesi
USFT-REMMELL-F14S15G5
3 Üyeler
14 adet Kılavuz yazıldı
1Rehber Yorum
Question what is the thing with a weird looking number 6 , right above the battery... I broke that and trying to replace it. Also can i replace the LCD only
DENNIS - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 19
Her zaman: 2,201
