Ana içeriğe geç
LG Optimus L7 P705 Headphone Jack Replacement
Neye ihtiyacın var
  1. LG Optimus L7 P705 Headphone Jack Replacement, Display: adım 1, 2 resimden 1. LG Optimus L7 P705 Headphone Jack Replacement, Display: adım 1, 2 resimden 2.
    • Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone.
    • Remove the battery and simcard.
  2. LG Optimus L7 P705 Headphone Jack Replacement: adım 2, 1 resimden 1.
    • Remove twelve 3mm screws (with the phillips head 000) around frame and near sim and sd cards.
  3. LG Optimus L7 P705 Headphone Jack Replacement: adım 3, 1 resimden 1.
    • Remove bottom plate where the charger port is located.
  4. LG Optimus L7 P705 Headphone Jack Replacement: adım 4, 2 resimden 1. LG Optimus L7 P705 Headphone Jack Replacement: adım 4, 2 resimden 2.
    • Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover.
  5. LG Optimus L7 P705 Headphone Jack Replacement: adım 5, 2 resimden 1. LG Optimus L7 P705 Headphone Jack Replacement: adım 5, 2 resimden 2.
    • Flip over to the face of the device.
    • Lift off glass screen (display).
  6. LG Optimus L7 P705 Headphone Jack Replacement, SIM Card Slot: adım 6, 2 resimden 1. LG Optimus L7 P705 Headphone Jack Replacement, SIM Card Slot: adım 6, 2 resimden 2.
    • Flip over to the back of the device
    • Using the plastic spudger, lift off the three board-to-board connectors on the left-hand side of the device.
  7. LG Optimus L7 P705 Headphone Jack Replacement: adım 7, 1 resimden 1.
    • Using a plastic spudger, lift off the wire connector at the right bottom of the board.
  8. LG Optimus L7 P705 Headphone Jack Replacement: adım 8, 2 resimden 1. LG Optimus L7 P705 Headphone Jack Replacement: adım 8, 2 resimden 2.
    • Detach the mount including both the SIM card and the motherboard from the device.
  9. LG Optimus L7 P705 Headphone Jack Replacement, Headphone Jack: adım 9, 1 resimden 1.
    • Lift off the connector using the plastic spudger.
  10. LG Optimus L7 P705 Headphone Jack Replacement: adım 10, 1 resimden 1.
    • Lift the speaker connector using the plastic spudger.
  11. LG Optimus L7 P705 Headphone Jack Replacement: adım 11, 3 resimden 1. LG Optimus L7 P705 Headphone Jack Replacement: adım 11, 3 resimden 2. LG Optimus L7 P705 Headphone Jack Replacement: adım 11, 3 resimden 3.
    • Flip over to the back of the device. Lift off the connector on the left using the plastic spudger.
    • Lift off the headphone jack connector on the top right using the plastic spudger.
    • Replace the board containing the headphone jack.
Sonuç
Tianyu Song
107 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 2-2, Baechle Spring 2017 IUPUI, Team 2-2, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S2G2
4 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 408
