Ana içeriğe geç
LG Optimus L9 P769 Micro-USB Port Replacement
Neye ihtiyacın var
  1. LG Optimus L9 P769 Micro-USB Port Replacement, Micro-USB Port: adım 1, 1 resimden 1.
    • Power off the device and gently lift the battery cover off to access the battery
  2. LG Optimus L9 P769 Micro-USB Port Replacement: adım 2, 1 resimden 1.
    • Lift and remove the battery from the notch in the edge of the battery compartment
  3. LG Optimus L9 P769 Micro-USB Port Replacement: adım 3, 2 resimden 1. LG Optimus L9 P769 Micro-USB Port Replacement: adım 3, 2 resimden 2.
    • Remove all 10 of the 4.5mm screws that hold the back frame to the case of the phone using a PH000 screwdriver.
  4. LG Optimus L9 P769 Micro-USB Port Replacement: adım 4, 2 resimden 1. LG Optimus L9 P769 Micro-USB Port Replacement: adım 4, 2 resimden 2.
    • Using a small prying tool, carefully remove the back frame by prying on the sides of the device.
    • Do be careful when prying back frame and removing it as too much force may result in damaging the frame.
  5. LG Optimus L9 P769 Micro-USB Port Replacement: adım 5, 3 resimden 1. LG Optimus L9 P769 Micro-USB Port Replacement: adım 5, 3 resimden 2. LG Optimus L9 P769 Micro-USB Port Replacement: adım 5, 3 resimden 3.
    • Remove both connections of the antenna by pulling up with tweezers
  6. LG Optimus L9 P769 Micro-USB Port Replacement: adım 6, 3 resimden 1. LG Optimus L9 P769 Micro-USB Port Replacement: adım 6, 3 resimden 2. LG Optimus L9 P769 Micro-USB Port Replacement: adım 6, 3 resimden 3.
    • Remove Micro-USB Cache by unscrewing both 2.9mm screws with the PH000 headtype
  7. LG Optimus L9 P769 Micro-USB Port Replacement: adım 7, 1 resimden 1.
    • Detach module from motherboard using a prying tool
  8. LG Optimus L9 P769 Micro-USB Port Replacement: adım 8, 2 resimden 1. LG Optimus L9 P769 Micro-USB Port Replacement: adım 8, 2 resimden 2.
    • Remove 1.8mm screw to free Micro-USB module for removal using the PH000 headtype
  9. LG Optimus L9 P769 Micro-USB Port Replacement: adım 9, 2 resimden 1. LG Optimus L9 P769 Micro-USB Port Replacement: adım 9, 2 resimden 2.
    • Use a small prying tool to detach the Micro-USB circuitry from the case of the phone
  10. LG Optimus L9 P769 Micro-USB Port Replacement: adım 10, 1 resimden 1.
    • Comparison showing the Micro-USB module against the empty phone casing
Sonuç
Kayden G
272 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G1, Harley Spring 2017 IUPUI, Team S2-G1, Harley Spring 2017 üyesi
IUPUI-HARLEY-S17S2G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 318
