Ana içeriğe geç
LG Optimus L9 P769 Rear Facing Camera Replacement
Neye ihtiyacın var
  1. LG Optimus L9 P769 Rear Facing Camera Replacement, Removing the Back Panel: adım 1, 2 resimden 1. LG Optimus L9 P769 Rear Facing Camera Replacement, Removing the Back Panel: adım 1, 2 resimden 2.
    • Pry the back panel from the frame of the phone to reveal the motherboard.
  2. LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard: adım 2, 3 resimden 1. LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard: adım 2, 3 resimden 2. LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard: adım 2, 3 resimden 3.
    • Detach the connectors on the motherboard.
  3. LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard Cont.: adım 3, 3 resimden 1. LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard Cont.: adım 3, 3 resimden 2. LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard Cont.: adım 3, 3 resimden 3.
    • Continue to lift the connectors off the motherboard.
  4. LG Optimus L9 P769 Rear Facing Camera Replacement, Lifting Motherboard from the Phone: adım 4, 3 resimden 1. LG Optimus L9 P769 Rear Facing Camera Replacement, Lifting Motherboard from the Phone: adım 4, 3 resimden 2. LG Optimus L9 P769 Rear Facing Camera Replacement, Lifting Motherboard from the Phone: adım 4, 3 resimden 3.
    • Lift the speaker cable off the motherboard.
    • Lift the motherboard up. It will Still be connected to the frame.
  5. LG Optimus L9 P769 Rear Facing Camera Replacement, Pry and remove the camera: adım 5, 3 resimden 1. LG Optimus L9 P769 Rear Facing Camera Replacement, Pry and remove the camera: adım 5, 3 resimden 2. LG Optimus L9 P769 Rear Facing Camera Replacement, Pry and remove the camera: adım 5, 3 resimden 3.
    • Pry under the camera to lift it off the frame.
    • There is some adhesive that will keep it attached to the frame, pulling the camera off will not damage the phone.
    • The camera should now be entirely separated from the phone.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Paul
145 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 8-1, Leahy Fall 2014 USF Tampa, Team 8-1, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S8G1
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 964
