Giriş
This repair requires the user to disassemble the device completely, removing the screen to reach the front facing camera. The user should be cautious when removing ribbon cables to ensure that they are not torn or broken. The user should also take extreme care when removing the motherboard as it is very delicate and easily damaged.
Neye ihtiyacın var
Start by placing the device face down and remove the back cove.
Remove the battery from the phone by lifting it using your finger or the prying tool
Using a spudger or small prying tool, pry off the latches that connects the digitizer to the chassis carefully.
Once the screen has been removed, use a prying tool to lift off the front facing camera.
