Ana içeriğe geç
LG Optimus T Button Replacement
Neye ihtiyacın var
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Using a prying device, such as a Spudger, remove the phone's back cover. At the top of the phone, there's an indentation to put the Spudger into to pop the case off.
    FixBot'a Sor
    Yorum Ekle
  1. LG Optimus T Button Replacement: adım 2, 1 resimden 1.
    • Remove the battery. There's an indentation to the left of the camera lens to pull up on the battery with your finger.
    FixBot'a Sor
    Yorum Ekle
  2. LG Optimus T Button Replacement: adım 3, 1 resimden 1.
    • Use a J0 screwdriver to remove the six 4.5 mm screws.
    FixBot'a Sor
    Yorum Ekle
  3. LG Optimus T Button Replacement: adım 4, 2 resimden 1. LG Optimus T Button Replacement: adım 4, 2 resimden 2.
    • Remove interior case. Insert the spudger into the indentations at the top or bottom of the phone to pry off the interior case.
    • You might have difficulty popping the case off. You may use the metal spudger if the plastic one fails. Be cautious when using it, as the metal spudger may damage your phone.
    FixBot'a Sor
    Yorum Ekle
  4. LG Optimus T Button Replacement: adım 5, 3 resimden 1. LG Optimus T Button Replacement: adım 5, 3 resimden 2. LG Optimus T Button Replacement: adım 5, 3 resimden 3.
    • Remove power button found on top of the phone.
    • Remove the volume button found on the side of the phone.
    • There is an indentation that has been marked near the edge that part of the volume button inserts in to. You will use this when reassembling your phone.
    • When reassembling your phone, place buttons on the metal nodes that have been marked.
    FixBot'a Sor
    Yorum Ekle
  5. LG Optimus T Button Replacement: adım 6, 1 resimden 1.
    • Pull up on connector tab.
    FixBot'a Sor
    Yorum Ekle
  6. LG Optimus T Button Replacement: adım 7, 2 resimden 1. LG Optimus T Button Replacement: adım 7, 2 resimden 2.
    • Remove SD card mount. Insert a plastic opening tool on the right side to pop off.
    FixBot'a Sor
    Yorum Ekle
  7. LG Optimus T Button Replacement: adım 8, 2 resimden 1. LG Optimus T Button Replacement: adım 8, 2 resimden 2.
    • There are 4 retaining points to insert a plastic opening tool into and pop off panel.
    FixBot'a Sor
    Yorum Ekle
  8. LG Optimus T Button Replacement: adım 9, 1 resimden 1.
    • Remove 2 black J0 Phillip's head 1.8 mm screws from charging port.
    • Charging port and motherboard are connected.
    • Remove motherboard.
    FixBot'a Sor
    Yorum Ekle
  9. LG Optimus T Button Replacement: adım 10, 2 resimden 1. LG Optimus T Button Replacement: adım 10, 2 resimden 2.
    • Pop off home buttons.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Patrick Esguerra
126 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-3, Wilder Spring 2017 Ohio State, Team 1-3, Wilder Spring 2017 üyesi
OSU-WILDER-S17S1G3
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 26
Her zaman: 428
